I am trying figure out if I can add an .sil condition to the "create" transition in my workflow where, depending on the value of a particular field, it either goes down "Path 1" or "Path 2" of the workflow. To give a little more context, I'm aware that you can't create custom epics in Jira, so Im basically trying to create 2 workflows in 1 issue type.
Ex. EPIC-123 has a field called "Epic Type" (drop down, single-choice field)
IF EPIC-123, Epic Type = "Type A" THEN Status = "Ready For Review"
IF EPIC-123, Epic Type = "Type B" THEN Status = "To-Do"
Something to that effect. the "Type B" in this scenario is a super simple "To Do, In Progress, Done" that a lot of users don't want modified. But the "Type A" Epic, has a very specific and very different set of steps and validations.
All this being said, I am open to alternative ideas. I went through a lengthy process of creating an additional issue type, setting up notification schemes, workflow post-functions etc. only to then find out, that I can't leverage Parent Link the same way actual Epics do. Also, can't use epic links, colors, etc. So this .sil script is my Plan B.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
