How can I create a workflow for Release Management?
Aurélie Henry
May 6, 2019
Dear community,
I am working on a multi agency project and if Jira is perfect to track work, backlogs and versions, the release part of the process is not tracked yet.
A release to live instances requires coordination between 3 or 4 agencies + client and we are using email to monitor the different steps (code, content, activation, clear cache, live reviews...)
I'd like to monitor the technical steps of the release/editorial publication using a Jira workflow or any other tool but email ;)
Thank you so much for any recommendation in that regard.
Best,
Aurélie
3 comments
David Berclaz _Apwide_
Hello @Aurélie Henry
For this kind of use case, I would use a new Jira issue type (called Release or Deployment) with:
  • A custom workflow for the main steps that cannot be done in parallel
  • Sub-tasks for the operations that can be done in parallel
There are some plugins that can be used in order to automatically create a set of Sub-tasks at the creation of the issue. And move automatically to the next workflow status when all Sub-tasks are closed.
Hopefully that helps, let me know should you need more details.
David
Aurélie Henry
May 7, 2019
Dear David,
This is a brilliant idea, simple and straight forward.
I should have thought about that ;)
Have a wonderful day,
Thank you very much,
Best,
Aurélie
@Aurélie Henry, your're welcome!
David
Yuri Kudin _Release Management_
May 21, 2019 edited
Hi @Aurélie Henry
We have created a Release management Jira app which should cover your needs.
So you don't need to create a separate project + will get full integration with Jira native versions and their issues.
 The add-on helps to:
  • Define custom versions workflow, track current status and transition history.
  • Easy to use Kanban board with all versions
  • Aggregate several versions from multiple projects into complex release. Complex releases can have own workflow (for instance, you might need to do  end-to-end testing when all components  will be released)
  • Manage and aggregate issues on version and complex release levels
  • Bulk operations: version create, update status, archive and unarchive
  • Visualize release plan on a timeline
  • + gadgets, reports and other "cookies" :)
Yuri
yurikudin
July 1, 2020 edited
Hi Community,
I am proud to announce that the Release Management is available for cloud
 In the cloud version, we have:
  • Custom workflow for version and package (cross-project, multi-version entity)
  • Representation of the version and packages on a timeline and as a Kanban board
  • Ability to see and manage the content of each version or package
  • Automated release notes aggregator
  • Set of gadgets that can help you to create informative dashboards for management
Hope you will enjoy it. As usual, your feedback is highly appreciated.
Yuri
Like • Ivan Nikolic likes this
Nikki Zavadska _Appfire_
Hi @Aurélie Henry
I recently wrote an article about creating release templates that might answer your question. It explains how to set up a release management workflow using one of our apps Swanly. But even if you won't use the app you might find it useful.
Link for the article 👉https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Jira-Release-Management-How-to-improve-your-release-process/ba-p/1361739
I hope that helps :)
Like • 2 people like this
