×I linked one of the issues to an EPIC of another project. As soon as I did that, the particular issue stopped being visible on the board itself. What could be the reason and how do I fix this?
Solved! Go to Solution.
Hey Joy. Got it. But the problem then would be that all issues from other projects would then start reflecting here.
My current query is " project = AD "
The EPIC is in another project which is "AAP". In general, for this project, the ticket will get associated with EPICs of 2 other projects which are "AAP" and "AIES".
My requirement is that the in project I only want issues belonging to AD to be visible on the board while having the ability to associate them to EPICs of another project.
Is this possible?
Let me clarify your request for my understanding:
Yes, it is possible.
With limited understanding of your current jira configuration I'd suggest you try the following queries.
Options:
Caveat:You must have access to the other boards as a user.
Continue to tweak it based on your configuration, these should give you a starting point.
Joy
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
