Starting a new carreer as manager of a PMO. i have worked for years in JIRA and confluence so very fluent but would like to really look at some solid work out there to put together a PMO using these tool sets and best way to configure.
Such an interesting topic.
I think you can try to answer the following questions to expand the scope of discussion on this topic.
The tools are just means to an end. I would recommend first this video:
Then, you can configure your tools according your goals.
If you want to follow a tradditional approach, check Advanced Roadmaps.
Jira is a very powerful tool but as any tool it has its limitations, if the focus is to use the tool for a team to fit how a tool works can create a lot of challenges and disagreements as not all teams execute the same type of work or solve the same kind of problems.
From an agile perspective, one size does not fit all.
However with the proper configurations and knowledge, Jira and other Atlassian tools can be set up to unleash the power of teams and bring up your game for solid teamwork.
Now, Jira allows to manage projects and teams, however you can always use Confluence to create high-level views for a program that might require multiple Jira projects as this is not possible with Jira (You can use roadmaps in Jira but is only for one Jira project), that means that you'd need to look into additional Atlassian products to create Roadmaps and higher level views, for visualizing at a program / initiative level that might require to retrieve data from more than 1 project.
Happy to chat more if you have any other questions!
Hi Claudia, possible to expand on the steps / tools and workflow required in confluence or these additional recommended products to create the views from a programme management perspective, please?
Definitely Atlassian Marketplace is the best place to start.
Here you can find "Power-Ups" for JIRA, Confluence and other Atlassian Products!
One of my favs from our partner, Old Street Solutions, have for Jira and Confluence Custom Charts.
You can explore to see what app can fulfill your use case :)
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
