Whether you’re managing a large project or preparing for an audit, one thing is clear: you need accurate, exportable data from Jira Data Center.
The next is common to project managers: stakeholders need reports, auditors need a detailed history of activities, and compliance departments need clear traceability. Jira Data Center has all this data, but it is not always simple to export it in an appropriate format (with an appropriate level of detail).
The good news? Jira offers several native export options, including exporting an individual issue and a filtered list of issues using JQL. However, you may not be able to find a complete history of changes. Jira allows exporting only show the current state of issues, not the full history of changes. This can be a major blocker during audits or compliance reviews.
This article provides five effective methods for exporting tasks and project data in Jira Data Center. You may need to compile a project summary, track team performance, or respond to a compliance request, and these approaches will help you accomplish the task efficiently and accurately.
Ready, set, go.
In some cases, you may just want to share the information of one task. In this situation, Jira Data Center offers a fast and convenient way to export a single issue:
✅ When to use this:
⚠️ Limitations:
Once you need a complete list of the tasks of a particular project, you can use the basic search and export features of Jira Data Center. You need no JQL skills to do this. Just follow the next steps:
✅ When to use this:
⚠️ Limitations:
When you need to have a little more control over what you are exporting, such as filtering issues by sprint, date range, or custom field, then Jira Query Language (JQL) is your best choice. To use this method, do the following:
project = "YourProject" AND status = Done AND resolved >= startOfMonth()
project = "YourProject" AND priority CHANGED
💡 Tip: You can save your JQL as a filter in case you need to use it regularly.
✅ When to use this:
⚠️ Limitations:
Not always do you need a complete list of issues in list form or spreadsheet; you simply want to know what has been going on recently in a project. The Activity Stream gadget on a Jira Data Center dashboard comes in handy there. It presents a real-time feed of what has changed recently: issue changes, comments, status changes, and so on.
Although it is not a traditional export tool, it is a good way to visually check what is going on, and it can be saved. To use it, follow the next steps:
Wish to save it? Use a screenshot or print to PDF to share activity reports with your team.
✅ When to use this:
⚠️ Limitations:
Although Jira offers native tools to export the current state of issues, they are insufficient when you have to answer such questions as:
It is where the Issue History for Jira app comes in as a powerful tool that allows you to track and export the complete history of changes to issues, and it is particularly useful during audits, compliance reviews, and retrospective analysis.
After the app installation, you can do the following:
- Project: Choose the project you need.
- Date Range: Select a specific time frame (e.g., This month).
- User: Filter by users to track individual activity.
- Columns: Focus on specific fields, such as Status, Priority, Due Date, etc.
The example of the downloaded tasks in Excel format:
💼 Use case: Preparing for an audit? All you have to do is put a date range, choose the project, and export all issue updates done within that period. In minutes, you will have a complete report.
✅ When to use this:
🟢 Why Project Managers choose this app:
⚠️ What to keep in mind:
🎯 Real-world example:
Imagine your compliance officer asks: “Can you show me all description changes made in the Finance project in Q2?”.
With the app, that’s a 60-second task:
🏢 Use Jira Data Center? Easily export full issue history (statuses, fields, priorities, deadlines) in seconds with Issue History for Jira app. |
☁️ Use Jira Cloud? Track and export every issue change for compliance, audits, and reporting with Issue History for Jira app. |
Data exporting of Jira Data Center does not need to be complex. Need a snapshot of issues today, a comprehensive project report, or a comprehensive audit of change details? You can have a method that works.
When it comes to everyday reporting, native tools are a great fit; however, in cases of accuracy and history, the Issue History for Jira app becomes the missing link. It provides you with a clear view of what, when, and who made the changes, all in a few clicks.
1. Can I export the full change history of tasks using Jira’s built-in features?
No. Native Jira exports only give the current issue state. An app such as Issue History for Jira will be required to obtain a complete change history.
2. When should I use JQL for exporting tasks?
Apply JQL in case of filtered exports (e.g. issues added this month, tasks reopened, or by assignee). These exports can be easily used with saved filters.
3. How does Issue History for Jira app improve exports?
Natalia_Kovalchuk_SaaSJet_
Product Marketer
SaaSJet
2 accepted answers
0 comments
