How to Do Capacity Planning in Jira: A Simple Guide
Let’s face it—capacity planning can sound like some hardcore project management mumbo jumbo, but it doesn’t have to be! If you’ve ever wondered how much work your team can handle without imploding or missing deadlines, capacity planning is your answer. And guess what? You can totally nail it using Jira.
What is Capacity Planning?
In simple terms, capacity planning is figuring out how much work your team can realistically handle during a certain period (usually a sprint or a project phase). It helps you avoid overloading your crew and ensures that tasks get completed on time without burning everyone out.
How to Do Jira Resource Capacity Planning
While Jira's core strength lies in issue tracking and project management rather than dedicated capacity visualization, you can still lay a foundation. By diligently setting team member availability and consistently estimating tasks (using story points for agile forecasts or time estimates for more predictable work), you can manually review sprint backlogs or team workloads.
For instance, in a Scrum setup, you'd ensure the total story points assigned in a sprint don't drastically exceed the team's historical velocity, which acts as a proxy for capacity. For Kanban teams, monitoring work-in-progress (WIP) limits in relation to team size and throughput can offer a continuous view of capacity utilization.
1. Estimate Task Duration
Jira allows you to add estimates for each task. Estimating task duration accurately is critical for capacity planning because it determines how much work can be assigned within a sprint. For your convenience, you can also add fields for the remaining estimate too.
You can use Jira’s Story Points or Time Estimates (in hours or days). Whichever metric you choose, ensure it aligns with your team’s working methods:
  • Time Estimates work well for teams where task durations are relatively predictable.
  • Story Points are better suited for Agile teams that estimate work complexity and effort instead of duration.
2. Plan Sprints Around Capacity
Once you’ve set up your team’s capacity and added estimates to your Jira tasks, you can start planning your sprint. The goal is to ensure that the total workload for each team member stays within their available capacity. Here's how:
  • Create a sprint in Jira (learn how).
  • Assign tasks to team members based on their available capacity. Use the estimate-to-capacity ratio to ensure that no one is overbooked.
  • Jira’s burndown charts can help track progress over time and ensure that you’re staying within capacity.
3. Plan Capacity Visually
If you want to ease your life, use the timeline view to visualize team capacity. There are multiple options to do it in Jira. The most evident is Jira Plans. The view is good for the overall view but has some limitations you should know about:
  • Only shows team capacity, no individual tracking
  • You can’t set skills and roles for team mates
  • Doesn’t include vacations and days off
  • The same capacity for everyone
If these limitations don’t fit your ideal workflow, investigate Jira third-party apps for capacity planning. One of them is Planyway.
Jira Capacity Planning with Planyway
If you want to level up your Jira capacity planning, Planyway is your secret weapon. With its easy-to-use interface and powerful capacity management features, you can visualize who’s doing what and make smarter decisions. Here’s how:
1. Set capacity for team members
You have full control over capacity in Planyway. While the system defaults to 8 hours per day, you can easily customize individual working hours.
2. Manage workload
Balance workload just by dragging work items to the right or left on the timeline. You will see the workload indicators showing you if someone is under or over allocated. The workload is calculated automatically based on a person's capacity and either original, internal or remaining estimate.
3. Include vacations and other days off
Include all vacations, holidays, and days off to guarantee a truly realistic workload calculation.
4. Integrate time tracking and reporting
Need to know how long tasks are actually taking? With Planyway’s time-tracking tools, you can get real-time data on task progress.
5. Compare planned time vs tracked
Refine future planning and understand team efficiency with a comprehensive estimate vs tracked time report.
A Review from a Planyway User 💬
"Planyway completely transformed the way we handle capacity planning. Before using it, our team often found themselves overloaded or scrambling to meet deadlines. Now, with the visual workload manager and capacity limits, I can instantly see who’s overbooked and reassign tasks accordingly. It’s like a weight has been lifted off my shoulders as a project manager, and my team has noticed the difference too—they’re less stressed and more productive. Planyway truly makes capacity management effortless!"
Alex T., Agile Coach
Common Pitfalls in Jira Capacity Planning and How to Avoid Them
Even with the best tools, mistakes happen. Here are some common pitfalls you’ll want to avoid when doing capacity planning in Jira:
  1. Overloading your team. Just because a team member has 8 hours in a day doesn’t mean they can work 8 hours straight on one task. Make room for meetings, breaks, and unexpected tasks.
    • Solution: Factor in buffers for breaks and other non-task-related work.
  2. Inaccurate task estimates. If your time estimates are off, your capacity plan is useless. Learn more about task estimates here.
    • Solution: Use historical data to improve your estimates or use Jira’s time tracking to get more accurate as you go.
  3. Not updating capacity regularly. Life happens. People get sick, go on vacation, or get reassigned.
    • Solution: Regularly update your team's capacity in Jira to reflect real-world changes.
Benefits of Capacity Planning
So, why should you care about capacity planning? Let me hit you with a few reasons:
  1. Prevents Burnout. Ensuring that no team member is assigned more work than they can handle keeps stress levels down and morale high.
  2. Improves Predictability. When work is planned according to capacity, it becomes easier to predict how long tasks or projects will take.
  3. Better Resource Management. Knowing your team's capacity helps you allocate tasks efficiently and avoid underutilizing or overloading team members.
  4. Enhanced Communication. Capacity planning improves communication between project managers and team members, fostering transparency about workloads.
  5. Improves Delivery and Execution. Aligning tasks with available resources ensures smoother project execution and greater on-time delivery.
For larger organizations or those practicing scaled agile frameworks, capacity planning often extends beyond individual teams to program and portfolio levels. Tools within the Atlassian ecosystem, such as Jira Align, offer more sophisticated features for capacity planning across multiple teams and for longer-term horizons like Program Increments (PIs). These systems aggregate team-level capacity data to provide a strategic overview, helping to align development capacity with broader business objectives. While the principles remain similar, the tooling and scope become more comprehensive to manage interdependencies and larger initiatives.
Wrap-up
Capacity planning with Jira doesn’t have to feel like a chore. With the right approach and tools—hello, Planyway!—you can keep your team running smoothly without overloading them. Whether you’re trying to balance workloads, track time, or avoid common planning pitfalls, these tips should help you handle capacity like a pro. Keep your team happy, healthy, and always on track. ✌
11 comments
Laurie Sciutti
Great article, @Mary from Planyway !
Like Mary from Planyway likes this
Humashankar VJ
October 8, 2024
Great insights!
Stephen_Lugton
Thanks for the article @Mary from Planyway
Orlando Kelly
I don't see this anymore in the plans area, does this functionality still exist in Jira?
Like # people like this
Brandon Boelman
November 14, 2024
I am struggling to find the Manage Shared Teams and Global Availability in Jira (we are on Cloud Premium, IT staff has been unable to find any permissions that would apply.) Our teams only show a total capacity, which is not granular enough for me. I imagine Manage Shared Teams is Jira version and or permissions based?
Bojana Vasic February 25, 2025
Hi @Mary from Planyway
The link you shared with @Brandon Boelman is for data center not for cloud - is  member's global availability (single user capacity) available in cloud? Please share docs if it is.
I am on cloud premium and I only see team capacity available.
Many thanks! :)
Evgeniya Zemlyanskaya October 8, 2025
Thanks for the article! Planyway looks like an appropriate and valuable tool for my team. But what do you think about unplanned tasks? How do you recommend accounting for urgent requests or bugs that often "eat up" part of sprint during capacity planning in Jira?
Mary from Planyway
That's a fantastic and very common question when it comes to capacity planning! It's true that unplanned work like urgent bugs or last-minute requests can significantly impact a sprint, even with the best planning. Here's how you can approach accounting for them in Jira and Planyway:
1. Dedicate a Buffer for Unplanned Work:
This is perhaps the most crucial strategy. Instead of planning your team's capacity at 100%, always reserve a percentage of each team member's time for unplanned work.
  • How much? This depends on your team's historical data. Look back at past sprints to see how much time was typically consumed by unplanned tasks. A common starting point is 10-20% of a team member's capacity. If you have a highly unpredictable environment, it might even be higher.
  • In Planyway/Jira:
    • Planyway: When you're assigning tasks, simply don't fill up 100% of a team member's estimated capacity in the timeline. Leave that buffer visibly free. This serves as a visual reminder that not all time is allocated.
2. Triage and Prioritize Unplanned Work Immediately:
When an unplanned task comes in, it's essential to have a clear process for how it's handled.
  • Triage Meeting: Hold a quick daily stand-up discussion or a dedicated "bug triage" meeting to assess the urgency and impact of new requests.
  • Prioritization: Determine if the unplanned task:
    • Must be done this sprint: If it's a critical bug or a high-priority request that cannot wait, then you'll need to swap it for an existing sprint task (see point 3).
    • Can wait: If it can wait until the next sprint, add it to the backlog and prioritize it for future planning.
    • Can be done within the buffer: If it's small and fits within the dedicated buffer, great!
3. The "Swap" Strategy:
If an unplanned task is critical and cannot be deferred, something else in the current sprint needs to give way.
  • Protected Scope: Ideally, your team agrees on a set of "protected" sprint goals that are absolutely non-negotiable. If an unplanned task threatens these, the team needs to decide which other planned task of equivalent size will be pulled out of the sprint to make room.
  • Transparency: Make this decision transparent to stakeholders. Explain that the new urgent task requires de-scoping something else to maintain team focus and avoid burnout.
4. Track and Analyze Unplanned Work:
Over time, tracking the amount and type of unplanned work can give you valuable insights.
  • Retrospectives: Discuss unplanned work during sprint retrospectives.
    • What caused it?
    • Could any of it have been avoided with better planning or preventative measures?
    • Was the buffer sufficient?
    • How effectively did the team handle it?
  • Reporting:
    • Jira Dashboards: Create a dashboard that shows the number of new issues added to a sprint after it started, or issues with a specific "Urgent" label.
  • Adjusting the Buffer: Use this data to continually refine the size of your dedicated buffer for future sprints. If you consistently use up your buffer and still de-scope items, your buffer might be too small.
What do you think about these approaches? Have you tried any similar methods before?
Like Evgeniya Zemlyanskaya likes this
Cameron Wong
October 24, 2025
Is Global Availability feature available without JSM?
Mary from Planyway
@Cameron Wong
I'm afraid no.
There have been many changes since the article was first written. I've updated it today so that it stays relevant.
Availability feature can be reached with Planyway.
