Are you testing your migration workflow by creating multiple issues and experimenting with workflows, fields, and other Jira features? When your testing is complete, do you want to delete the issues but find the bulk change process tedious and limited to only 1,000 items at a time?
Our solution, BulkOps Pro is for you! As an administrator, it allows you to bulk delete Jira issues effortlessly using a JQL query. Simply enter your desired JQL, confirm your actions, and you're done. All these are done in 4 easy steps as described below
Navigate to the BulkOps Pro on your Jira instance and Click to Log in
Navigate to the projects overhead menu and click on “delete issues”
Type on the form a valid JQL or you can type issue keys separated by a comma. Both ways are possible
A valid JQL begins with the text “JQL:<jql statement>” e.g. JQL:project in (AB, CD) order by created DESC
Choose “Yes” to confirm the deletion of the issue
Try out our app (free for 30 days or completely free if your user base is under 10 users). Visit our documentation to get started and if in doubt, our expert support team on Jira would be able to answer any questions or use cases you may have.
ELFAPP Technologies
Service Provider/Administrator
ELFAPP Technologies
Netherlands
7 accepted answers
0 comments
