How to work with Custom fields in Jira if you need to add some custom fields to your Jira issues? This article will help you to find it out on the example of SLA Time and Report for Jira add-on, which is an SLA tracking, reporting and monitoring tool for Jira.
Note: you can apply these steps to any other case. It works not only for Jira SLA plugins, or time tracking plugins.
Let’s look at how to do this in “Next-Gen” Jira projects, which are also “Team-managed” projects.
Here you have to create custom fields manually.
For this, go to the Project settings, open the Issue type settings and add the Custom fields you need.
To add them, move “Time stamp” and “Label” fields to the Context fields.
Note: don’t write anything in the “Description” fields, leave them empty. Our add-on will fill them in automatically.
Here is how your Jira issue will look like when custom fields are added:
Now it’s time to start creating a new SLA Configuration.
Make sure you won't miss the deadline and will move as you planned by pinning the Custom field with SLA date and status to the top. Just click the “Pin” button, and the custom field will be at the top over other issue fields. If you need them to be moved back, click the “Unpin'' button, and this custom field will be back at its previous position.
Now you know how to add custom fields to your Jira issues, connect them to your SLA Configurations, and set time goals in SLA Time and Report for Jira add-on, which according to the date and time stated in these custom fields.
Try SLA Time and Report for Jira add-on and achieve your time goals easily.
Olha Onofriichuk_SaaSJet
Product Marketing Manager
SaaSJet
3 accepted answers
0 comments
