The best way to keep Jira issues in sync across teams and tools
I wanted to share some thoughts on a topic that comes up often in conversations with teams managing complex Jira workflows: syncing issues across multiple platforms and tools.
It’s something that can transform how your teams collaborate, and having been in the trenches myself, I know how tricky it can be to get it right.
At its core, Jira issue sync is the process of synchronizing issue data between multiple Jira sites, projects, instances, or other tools (like GitHub, Azure DevOps, or Salesforce).
This ensures every update—such as issue status changes, comments, or assignee modifications—is reflected in the connected system in real-time.
For teams working across these diverse platforms, syncing Jira issues reduces manual work, improves transparency, and keeps everyone aligned without forcing them to switch tools.
Native functionality: helpful, but limited!
Jira does offer native ways to link and integrate with other tools. For example, you can connect GitHub pull requests to Jira issues. Sounds great, right?
But here’s the catch: these integrations often stop short of real-time, bidirectional syncing.
For example:
  • Teams using GitHub may not see real-time updates within Jira, creating silos.
  • Product managers in Jira may miss critical comments or changes from developers working in GitHub.
Plus, you can also use Jira Automation, but again it’s very basic in functionality and you cannot implement a fully functional bidirectional Jira integration with it.
If you need a robust solution where all updates sync seamlessly, third-party issue sync apps like Exalate offer far more functionality and control.
My top use cases for Jira issue sync
  1. Sync between multiple Jira instances:
     Keep multiple Jira instances synchronized for cross-team collaboration without manually duplicating updates. Even connect private and public Jira instances.
    Example: Sync Jira Service Management and Jira Software tickets to improve workflows between support and engineering teams.
  1. Jira GitHub issues integration (Jira + GitHub):
    Allow GitHub engineers and Jira-based product managers to work in their preferred tools while staying aligned. Automatically sync GitHub issues with Jira tasks.
    Sync fields like issue status, assignee, comments, and labels.
  1. Automate software development workflows (Jira + Azure DevOps)
    Sync Jira issues with Azure DevOps work items to automate workflows across development and product management teams.
    For example:
    - Link Jira epics to Azure DevOps features, ensuring traceability between requirements and development progress.
    - Sync issue statuses, comments, and assignees so that updates made by developers in Azure DevOps are instantly reflected in Jira.
    - Automate the handoff process: when a task is marked "Done" in Azure DevOps, it transitions to "Ready for Review" in Jira.
  1. Shared Jira projects across departments:
    Collect all bugs into one central Jira project and sync them to the right team’s project for resolution.
  2. Sync Jira issue statuses automatically:
    Ensure changes in issue status (e.g., "In Progress" to "Done") in one project reflect in all linked instances or tools.
  3. Bug triage across teams:
    Log bugs in one Jira project and sync them to other teams’ Jira or GitHub projects for faster resolution.
  4. Client-vendor collaboration:
    Sync Jira tickets between your instance and your client’s instance to improve communication and alignment without exposing internal data.
  5. Agile release management:
    Sync epics, user stories, and tasks across Jira projects to coordinate agile releases effectively across multiple teams.
Why consider Exalate?
Exalate is designed for advanced Jira sync use cases and offers:
  • Real-time, bidirectional synchronization: Automatically sync all default and custom issue fields, comments,  and workflows in both directions across tools like Jira, GitHub, ServiceNow, Zendesk, and Salesforce.
  • Granular customization: Use scripting (powered by AI) to define exactly which fields, workflows, or updates to sync or not to sync—perfect for complex setups.
Why does syncing Jira issues matter?
When done right, syncing Jira issues:
  • Eliminates manual data updates and reduces errors.
  • Enhances team productivity by letting everyone work with their preferred tools.
  • Keeps workflows aligned across platforms in real time.
If you’ve faced challenges with syncing Jira issues or are exploring use cases like the ones I shared, let me know in the comments or reach out. I’d love to hear about your experiences and help where I can.
Let’s sync smarter in 2025.
Best wishes all
0 comments
