🚀 Ultimate Condition and Validator - A Smarter Way to Build Jira Validators
We’ve been working on a more flexible way to build conditions using Jira Expressions, and that led to Ultimate Validator. It lets you use most of the power of Jira Expressions—but without writing code. Instead, you build conditions through a simple UI.
How Ultimate Validator Works
After selecting a source—such as a field or the current user—a list of operations appears. Each operator leads to the next until you reach a terminal operator that requires a value. The Jira expression preview is generated in real time, so you always know exactly how your condition works—no more guesswork.
Here’s what it looks like:
Common Use Cases
Here are some common scenarios where the Ultimate Validator simplifies complex conditions.
Making a Field Required Only in Certain Cases
Jira’s built-in Field Required validator doesn’t allow conditions—you either require a field for every transition or not at all. But often, you need a field to be required only when certain conditions are met.
With Jira Expressions, this is possible. For example, if you want the Root Cause field to be required only when Resolution is set to Fixed, you could write:
issue.resolution?.name == 'Fixed' ? issue.customfield_10126 != null : true
Alternatively, you can achieve the same result using the || (OR) operator. In this case, you'd need to invert the condition: allow the transition when the resolution is not 'Fixed', or require the "Root Cause" field otherwise:
issue.resolution?.name != 'Fixed' || issue.customfield_10126 != null
Ultimate Validator lets you set this up easily through the UI, with no need to write code.
Handling Rich Text Fields in Jira Expressions
If you are concerned about the recent changes in the multi-text field format during new Issue Transition, don't worry - the plainTextValue helper automatically handles the different formats for you.
There are a few key points to keep in mind when writing Jira Expressions manually. First, almost every field can be null, so you typically need to check for null before performing operations—otherwise, you may encounter a Syntax Error during execution.
Counting characters in Short Text fields is straightforward, but Rich Text (Paragraphs) can be tricky. Most rich text fields are stored as ADF (Atlassian Document Format) objects, meaning they need to be converted using new RichText(value) to access the .plainText property. However, some fields—like Description or Environment—are exceptions, as they are already converted when used in expressions.
Ultimate Validator takes care of these complexities, ensuring that your validation works correctly without requiring manual adjustments.
Counting Items in Multi-Select Fields
With the Count operator, you can validate how many items have been added or selected in multi-value fields, such as:
  • The number of attachments on an issue.
  • Whether only one option is selected in a multi-select field.
  • Ensuring a required number of checkboxes are selected.
  • Requiring a minimum number of Versions, Components, or Labels.
Validating Child and Linked Issues
Jira Expressions allow you to check relationships between issues. The key properties are:
  • subtasks → Returns an issue’s sub-tasks.
  • stories → Returns an Epic’s child issues (excluding sub-tasks).
  • childIssues → Returns both child issues and sub-tasks.
You can also test issue links (e.g., “blocked by”) and parent issues.
Example: Ensuring that time is logged on either an issue or one of its sub-tasks.
Properly Validating Cascading Select Fields
The built-in Field Required validator only checks if the parent option is selected—it doesn’t check the child option. This means a transition can still go through even if the child selection is missing, which isn’t always the expected behaviour.
This is a known issue, but Ultimate Validator provides a child option operator, allowing you to ensure that the child option is always selected.
Checking if an Issue is in an Active Sprint
You can check various sprint properties in Jira Expressions, such as start date, end date, completion date, and state.
To check if an issue is in the current sprint, validate the sprint state:
  • "active" → Sprint is in progress.
  • "future" → Sprint is planned but not started.
  • "closed" → Sprint has ended.
With Ultimate Validator, you can easily enforce sprint-based conditions without needing custom expressions.sprint_active.png
We’ve also published a follow-up: Ultimate Validator – Introducing WHEN → THEN clauses
I am from Forgappify and the Ultimate Validator is part of the Workflow Building Blocks for Jira app.
0 comments
