Adaptavist ScriptRunner for JIRA How to fix Error Required resource with name 'view' does not exis
Krasina Anna October 24, 2018 edited
Hello!
An error occurs when creating or editing web fragments.
The plugin itself works, but Script Fragmetns does not work.
We reinstalled the plugin, but it did not help.
Removing the plug-in with clearing the cache and restarting the service and reinstalling did not work either.
Is there any solution to the problem?
com.atlassian.plugin.PluginParseException: Required resource with name 'view' does not exist. at com.atlassian.plugin.web.descriptors.WebPanelSupplierFactory.getRequiredViewResource(WebPanelSupplierFactory.java:107) at com.atlassian.plugin.web.descriptors.WebPanelSupplierFactory.build(WebPanelSupplierFactory.java:56) at com.atlassian.plugin.web.descriptors.DefaultWebPanelModuleDescriptor.init(DefaultWebPanelModuleDescriptor.java:130) at com.atlassian.plugin.ModuleDescriptor$init$2.call(Unknown Source) at com.atlassian.plugin.ModuleDescriptor$init$2.call(Unknown Source) at com.onresolve.scriptrunner.fragments.FragmentsManager.register(FragmentsManager.groovy:248) at com.onresolve.scriptrunner.fragments.FragmentsManager.register(FragmentsManager.groovy) at com.onresolve.scriptrunner.fragments.IFragmentsManager$register.call(Unknown Source) at com.onresolve.scriptrunner.fragments.AbstractCustomWebPanel.doScript(AbstractCustomWebPanel.groovy:176) at com.onresolve.scriptrunner.canned.CannedScript$doScript.call(Unknown Source) at com.onresolve.scriptrunner.canned.CannedScript$doScript.call(Unknown Source) at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.validateAndRunCannedInternal(ScriptRunnerImpl.groovy:434) at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.runCanned(ScriptRunnerImpl.groovy:379) at com.onresolve.scriptrunner.fragments.FragmentsManager$_registerFragments_closure1.doCall(FragmentsManager.groovy:104) at com.onresolve.scriptrunner.fragments.FragmentsManager.registerFragments(FragmentsManager.groovy:103)...
Joshua Yamdogo @ Adaptavist
October 25, 2018
Hi Krasina,
There are many things that can cause this. Can you run this in the script console within JIRA and then tell me what it returns?
import com.onresolve.scriptrunner.fragments.FragmentsManager
import com.onresolve.scriptrunner.runner.util.AOPropertyPersister
def frags = AOPropertyPersister.loadMap(FragmentsManager.AO_PROPERTY_KEY)
log.warn frags
frags.toString()
Josh
Krasina Anna October 26, 2018
Thank you, we understood what the error was, it was caused by duplicates of Script Fragments. This problem and solution are described in SRPLAT-217
Like • vincent_marx_external likes this
October 26, 2018
Hi Krasina,
Glad to hear you resolved the problem!
Josh
