Changing options on radio buttons and setting fields hidden using script runner
Daniel Drysdale _UK_ October 12, 2019
I am using code to change the options on some radio buttons so i can remove the none option from showing.However I use a few of these radio buttons to hide other fields further down the form.
This is the code i use to hide the set the options.
and i use this to set the other fields hidden
both work on there own, however when i turn on the the first piece the second piece no longer detects what has been selected.
I use the same code succesfully on select lists and checkboxes so i am confused as to why it would not work with radio buttons, any help would be much appreciated
thanks
