×Hi. I need to make a REST call to another application from JIRA. The call needs to do a post of json data. I have spent all day googling this and can't come up with anything. Does someone have an example of where they are posting json in a groovy script? I am trying to do this in script runner. Thanks in advance. Mike
Here is the script I'm using to POST a translate text to translation service.
import groovy.json.JsonSlurper; import groovy.json.StreamingJsonBuilder; import com.atlassian.jira.ComponentManager; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.fields.CustomField; import com.atlassian.jira.issue.IssueManager; import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.Issue; import com.atlassian.jira.issue.MutableIssue import org.apache.commons.codec.binary.Base64; def user = "jira"; def issueID = ""; IssueManager issueManager = ComponentManager.getInstance().getIssueManager(); //MutableIssue Issue = issueManager.getIssueObject("DEMO-467"); MutableIssue Issue = issue; issueID = Issue.getKey(); def issueType = Issue.issueTypeObject.name; def textToTranslate = ""; def targetLanguage = ""; def originalLanguage =""; def languagesCodes = [ English:"EN", Spanish:"ES", Franch:"FR", German:"DE", Polish:"PL", Russian :"RU", Japanese:"JP", Portugese:"PT", Italian:"IT", Dutch:"NL", Turkish:"TR", Czech:"CZ", ] textToTranslate = "text to translate" targetLanguage = Issue.getCustomFieldValue(targetLanguageObject); def body_req = [ "user": user, "jiraTicket":issueID, "route":"/resources/text", "targetLang":languagesCodes[targetLanguage], "reqText":textToTranslate ] def baseURL = "http://production.******.com/api/translation"; URL url; url = new URL(baseURL); URLConnection connection = url.openConnection(); connection.requestMethod = "POST" connection.doOutput = true connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8") connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) } connection.connect(); println("url: " + url); println("Content:" + connection.getContent()) println("ResponseCode:" + connection.getResponseCode()) println("getResponseMessage:" + connection.getResponseMessage())
Hi Amit
Is this script working for you?
because I am trying to create Index in Elasticsearch on ticket creation but it is throwing 400 error code.
And same script is working perfect in Jenkins.
Thanks and Regards,
Vaishal
Hi Priva,
I am trying to create Index in Elasticsearch using REST API with same code but it won't be work.
Please find my code
import org.apache.log4j.Logger import org.apache.log4j.Level import groovy.json.JsonSlurper; import groovy.json.StreamingJsonBuilder; import org.apache.commons.codec.binary.Base64; //Debug def log = Logger.getLogger("com.acme.CreateSubtask") log.setLevel(Level.DEBUG) //Body def body_req = [ "settings": ["index": ["number_of_shards" : 3, "number_of_replicas" : 2] ] ] //Create Index with Jiraicket Name def baseURL = "http://localhost:9200/JiraTicket"; URL url; url = new URL(baseURL); HttpURLConnection connection = url.openConnection() as HttpURLConnection; connection.requestMethod = "POST" connection.doOutput = true connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8") connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) } connection.connect(); log.info("URL="+url+"Status="+connection.getResponseCode() as String)
Can you please help me to find where i did mistake.
Thanks and Regards,
Vaishal
You may need to set a request property for the authorization. Originally the code was giving me a 400 response code, but I added the following lines to fix the issue:
connection.setRequestProperty("Authorization", "Basic <encrypted credentials>")
I originally tested my request using the Chrome extention "POSTMAN." The applet allows you to input your username and password credentials and automatically generates the Authorization header for you. You would then just need to add the header as a request property, as shown above. Any method of encrypting your credentials should work, however.
Hope this helps!
Hi, this all works well, but the Response is empty. Running the command in browser or Postman the Response is filled as expected.
What can be the resason?
Thanks for helping.
Hi Mike,
I've found https://answers.atlassian.com/questions/178254/calling-rest-api-from-within-script-runner-post-function-and-needed-librariesthat might help you a little, at least to start.
Thanks Pedro. Here is an update...
I can run a GET just fine and it works...
def curl = "/usr/bin/curl -u admin:admin http://itest.com/jira/rest/api/2/issue/ITCMTEST-245"
def output = curl.execute().text
However, when I run the POST below, I get the following errors (I think it has to do with the double quotes and single quotes... I tried to escape them but get error '415 - Unsupported Media Type'... has someone been able to get this to work if so PLEASE help)...
def curl = "/usr/bin/curl -u admin:admin -X POST -d \'{\"fields\":{\"project\":{\"id\":\"12660\"},\"summary\":\"MIKE\",\"description\":\"BART\",\"issuetype\":{\"id\":\"76\"}}}\' -H \"Content-Type: application/json\" http://itest.com/jira/rest/api/2/issue/"
ERROR = <html><head><title>Apache Tomcat/7.0.29 - Error report</title><style><!--H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}A.name {color : black;}HR {color : #525D76;}--></style> </head><body><h1>HTTP Status 415 - Unsupported Media Type</h1><HR size="1" noshade="noshade"><p><b>type</b> Status report</p><p><b>message</b> <u>Unsupported Media Type</u></p><p><b>description</b> <u>The server refused this request because the request entity is in a format not supported by the requested resource for the requested method (Unsupported Media Type).</u></p><HR size="1" noshade="noshade"><h3>Apache Tomcat/7.0.29</h3></body></html>
