Environment:
JIRA v7.4.4,
ScriptRunner 5.3.5
Using the below, upon creation of the issue I expect the custom field (Support Forum Post Location) to only appear when one of components are selected, and then it should be required.
What is happening is the custom field does not appear initially on the create screen (expected) but also does not appear if I select either of the two components and try to create, the issue is created without showing and requiring the custom field.
If I edit an issue created like this, then the field is required as expected.
However, if I try to create with the Summary blank and one of the Component selected, then custom field appears and is required.
I am not using an Initialiser Function or "new condition", and have tried with the Use Validator Plugin enabled and disabled.
While we have experimented with Behaviors, this is the first need to get this up and running.
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
def hidefield = getFieldByName("Support Forum Post Location")
def component = getFieldById("components")
def componentV = component.getValue()
if (componentV.toString().contains("Customer Experience Process Improvement")) {
hidefield.setRequired(true)
hidefield.setHidden(false)
hidefield.setHelpText("This field is required when a Customer Experience issue is created")
else if (componentV.toString().contains("Customer Experience Support Community Item")) {
} else {
hidefield.setHidden(true)
