Sign up Log in
Problem with groovy and postfunction
Urszula Forenc
we have a groovy, that do not work from several weeks:
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder;
import com.atlassian.jira.issue.util.IssueChangeHolder;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.issue.customfields.manager.OptionsManager;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
IssueChangeHolder changeHolder = new DefaultIssueChangeHolder();
def userManager = ComponentAccessor.getUserManager();
def issueManager = ComponentAccessor.getIssueManager();
def jobInterviewerICSD = customFieldManager.getCustomFieldObjectByName("Job Interviewer I CSD");
def jobInterviewerIPBS = customFieldManager.getCustomFieldObjectByName("Job Interviewer I PBS");
CustomField privilegesField = customFieldManager.getCustomFieldObjectByName("Access privileges");
if(jobInterviewerICSD != null){
               ModifiedValue newPrivilegesField = new ModifiedValue(issue.getCustomFieldValue(privilegesField), jobInterviewerICSD);
               privilegesField.updateValue(null, issue, newPrivilegesField, new DefaultIssueChangeHolder());
               return privilegesField;
if(jobInterviewerIPBS != null){
               ModifiedValue newPrivilegesField = new ModifiedValue(issue.getCustomFieldValue(privilegesField), jobInterviewerIPBS);
The postfunction error shows:
2018-06-15 11:46:45,266 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2018-06-15 11:46:45,267 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: REC-19463, actionId: 891, file: /var/atlassian/application-data/jira/scripts/GroovyScripts/recruitnsc/scripts/set_access_privileges.groovy
java.lang.ClassCastException: com.atlassian.jira.issue.fields.ImmutableCustomField cannot be cast to java.util.Collection
      at com.atlassian.jira.issue.customfields.impl.AbstractMultiCFType.createValue(AbstractMultiCFType.java:39)
      at com.atlassian.jira.issue.fields.ImmutableCustomField.createValue(ImmutableCustomField.java:693)
      at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:410)
      at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:396)
      at com.atlassian.jira.issue.fields.OrderableField$updateValue.call(Unknown Source)
      at set_access_privileges.run(set_access_privileges.groovy:25
Do you see any possible errors?
Thank you
Alejandro Suárez García
There are several incorrect or improvable things in that script. What are you trying to do here?
