×Hello guys,
I'm using the scripting post function from Script Runner that clones one issue from one project to the other (Clones an issue and links), and i'm trying to set a field on the target clone issue by inserting code on the 'Additional issue actions' box on the post function setup, but maybe i'm doing something wrong, it is not working.
The code is to set a Select Field to a set value:
import com.atlassian.crowd.embedded.api.User import com.atlassian.jira.ComponentManager import com.atlassian.jira.bc.issue.IssueService import com.atlassian.jira.bc.issue.IssueService.UpdateValidationResult import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.IssueInputParameters import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.user.ApplicationUser import org.apache.log4j.Logger import org.apache.log4j.Level import com.atlassian.jira.issue.ModifiedValue import com.atlassian.jira.issue.util.DefaultIssueChangeHolder import com.atlassian.jira.issue.customfields.option.Options import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.customfields.manager.OptionsManager import com.atlassian.jira.issue.customfields.option.* CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); CustomField customField = customFieldManager.getCustomFieldObject("customfield_10802"); OptionsManager optManager = ComponentAccessor.getOptionsManager(); Options options = optManager.getOptions(customField.getRelevantConfig(issue)); Option newOption = options.getOptionForValue("Three", null); ModifiedValue mVal = new ModifiedValue(issue.getCustomFieldValue(customField), newOption ); customField.updateValue(null, issue, mVal, new DefaultIssueChangeHolder());
Am I doing something wrong?
Because if I use this code on a post function in the Create Issue transition, it works. But I really needed that working on the Cloning process.
Kind regards
Hi Ariel,
As long as your clone issue post function is the first one (or at least before the Update Issue post function) then in your additional code you will need something like
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.MutableIssue def issue = issue as MutableIssue def cf = ComponentAccessor.customFieldManager.getCustomFieldObjects(issue).find {it.name == 'SelectListA'} def value = ComponentAccessor.getOptionsManager().getOptions(cf.getRelevantConfig(issue))?.getRootOptions()?.find {it.value == "BBB"} issue.setCustomFieldValue(cf, value)
Please let me know if this does the trick
regards, Thanos
