ScriptRunner Post Function vs Listener Script for Watcher
Lubomir Styskala
October 12, 2018 edited
I have created a post-function script for adding a watcher to the issue when a custom field is equal to a value. But then I realized that the custom field can be changed so I decided to create another script as a script listener custom script, where I want to detect issue updated event and update watcher accordingly.
The problem is that the function for updating watcher is not working as in post-function script. Could you help me, what to change?
The error in script listener is like this:
and the script is at this time the same for post-function and listener (just copied it from post-function to listener script):
log.warn("Listener is fired");
import com.atlassian.jira.issue.watchers.WatcherManager
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.issue.CustomFieldManager
//grabing some methods
WatcherManager watcherManager = ComponentAccessor.getWatcherManager()
UserManager userManager = ComponentAccessor.getUserManager()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
//Get the custom field value. .toString() is a must for the commentManager.create function, othervise it is throwing a validation error.
def cField1 = customFieldManager.getCustomFieldObjectByName("Customer")
def cFieldValue1 = issue.getCustomFieldValue(cField1).toString()
log.warn("Show the custom field value:" + cFieldValue1)
//Adding a watcher when this condition is met
if (cFieldValue1 == "Something") {
def users = ["UserName"]
def watchUsers = {usernames ->;
usernames.each {
watcherManager.startWatching(userManager.getUserByName((String)it), issue)
watchUsers(users)
log.warn("true")
} else {
log.warn("false")
Kmmaughs
March 30, 2020 edited
It looks like the final answer was this format:
def issue = event.issue as MutableIssue
CustomFieldManager customField = ComponentAccessor.getCustomFieldManager()
def cField1 = customField.getCustomFieldObjectByName("Customer")
//Adding a watcher when this condition is met (NOTE: I used contains since my custom field was a multi-select)
if (cFieldValue1.contains("Something")) {
//Alternatively, you can use what was listed above: if (cFieldValue1 == "Something") {
def users = ["username"]
usernames.each {
watchUsers(users)
log.warn("true")
} else {
log.warn("false")
Daniel Yelamos [Adaptavist]
October 12, 2018
Hi Lubomir.
I think your postfunction is firing for sure. That is a static compilation error and I'm sure it's not what's making that postfunction fail. Could you add a
log.debug "I'm in the postfunction"
That way you can check the logs to make sure that it's actually getting executed.
Cheers!
DY
Lubomir Styskala
Hi Daniel,
it is working now. I will put the solution here later today. Thank you for your effort so far.
cheers,
Lubomir Styskala
Regarding the solution, I noticed that this definition was also marked by static type checking
So a added a few lines:
and
and the code started to work as expected. So it seems that the issue declaration is not needed in post-function but in Scripted Listener is needed. I don't know why, but it did the job and after that the code was clear.
