×I tried to change the help text of a field with Scriptrunner Behaviours according to https://scriptrunner.adaptavist.com/5.3.1/jira/behaviours-api-quickref.html with setHelpText(), but it somehow adds an additional red text, instead of replacing the small gray text under the field.
How can I do this?
My initializer script:
import static com.atlassian.jira.issue.IssueFieldConstants.*
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
import com.atlassian.jira.user.UserLocaleStore
@BaseScript FieldBehaviours fieldBehaviours
def currentUser = ComponentAccessor.getJiraAuthenticationContext().loggedInUser
def userLanguage = ComponentAccessor.getComponent(UserLocaleStore).getLocale(currentUser).language
def summaryLabel = "Staff Member Name"
def componentsLabel = "Organizational Unit"
def katTeamLabel = "Kanban Team"
def katTeamHelp = "Optionally define of which interdisciplinary teams the employee is part of."
getFieldById("summary").setLabel(summaryLabel)
getFieldById("summary").setRequired(true)
getFieldById("components").setLabel(componentsLabel)
getFieldById("customfield_12430").setLabel(katTeamLabel)
getFieldById("customfield_12430").setHelpText(katTeamHelp)
Hi Flaimo,
In that case you will need
getFieldByName("TextField").setDescription("This is a description from Behaviour")
Let me know if this does the trick.
Regards, Thanos
You should document this under https://scriptrunner.adaptavist.com/5.3.1/jira/behaviours-api-quickref.html
That's a fair point Flaimo, we will fix it. Thanks for pointing this out.
This is still not updated on the API Quick Reference. It's a rather difficult problem to google too, since there are so many examples that modify the "Description" *Field* itself.
https://scriptrunner.adaptavist.com/latest/jira/behaviours-api-quickref.html
After playing around with the setDescription() method, it seems like it would be extremely useful to have some kind of resetDescription() method to change it back to the unmodified text (e.g. what's set in the Field Configuration).
Basically, we have a use-case where our user wants to conditionally set the description of a field, when a specific value is selected in another field. setDescription() lets us do this for that specific value, but if the user then changes their choice to a value that should *not* modify the description, it continues to display the modified description.
The only workaround I could think of here would be to abandon setting a description in the Field Configuration entirely, and use setDescription() calls in the Behaviour exclusively (for both positive and negative cases)
Still not updated
But at least this is the first thing that pops up after googling.
I would have expected setHelpText to Set Help Text, but it styles it like an error. I tried to restyle it using CSS but there isn't enough difference between "help text" and a real error to make the selectors work.
