×Our customers have emphasized the importance of goals in planning. We've listened to your feedback and shipped enhancements to Goals, making it easier to plan, share updates and insights.
6 options to suit your needs. With 6 pre-designed templates, you can choose the one that is right for the update youโre giving.
Crafting updates got simpler. Start with key highlights or even embed videos for a richer experience. With a variety of options, staying on top of your goals updates has never been easier.
Streamlined formatting. With consistently formatted goal updates, you can ensure clear understanding of progress across your colleagues, teams, or the whole company. Make it easier on readers by sticking to the update format that makes the most sense for your goals.
Read more about how to write great updates here
You can now add teams directly to the goals theyโre working on. Look for the Teams section in the goal sidebar and add the teams that are contributing to the goal.
Once a team is added to the goal, that goal will be listed under the Contributing to widget on the Teamโs profile. That way, you can easily find all the goals that a team is contributing to.
Some goals take a long time to achieve, so apart from knowing the target date you also want to know when did the work on this goal start.
With start dates for goals you can track when a particular goal was started, without having to scroll down on the list of updates to find the very first update.
It also enables you to plan ahead and set goals that will be started in the future.
With new goal insights, your goals are more than progress reports โ they become teachable moments that offer valuable nuggets of knowledge for your followers.
Gain a deeper understanding: Followers can grasp the nuances of your journey and sift through the noise with key Risks and Decisions
Extract valuable lessons: Others pursuing similar goals within your company can learn from your experiences and avoid potential pitfalls with Learnings. Read more about Learnings here.
Whenever you embed a topic across other Atlassian products, the new goals tab shows the latest updates, status, and target date for all of the goals that contribute to that topic.
Yerbol Nisanbayev
Product crowd @Atlas
Atlassian
1 accepted answer
8 comments
