×Got a question about Atlas? Check out the below, or find more FAQs in our collection.
Got any suggestions to include? Comment below! ⤵️
Our simple definition is:
Projects: Think of this as a team (e.g. two or more people working to produce something for two or more weeks).
Goals: Think of this as an outcome one or many project teams are trying to achieve. For simple setups, one project could map to one goal - but as organizations and teams grow, often many teams have local goals but contribute to bigger department or company-wide goals. Atlas helps your teams grow.
Learn more in our article.
It’s important to remember that Atlas and Jira Software solve different problems.
Jira Software solves the problem of planning and task management within teams. It offers granular detail and context for stakeholders within a team.
Atlas solves the problem of communication and alignment across teams. It brings clarity to the complex, detailed work happening in Jira Software to all teams in an organization.
Atlas provides curated (not automated!) updates and shows how work happening in Jira Software contributes to bigger objectives.
For more information, check out this article.
Check out our article on how they work together.
Project management tools, such as Jira Work Management or others, help teams plan and manage their work down to the smallest detail.
Atlas helps teams communicate context and progress about work happening, whichever tools are used.
The Loop is a framework for healthy and effective communication across teams. We use it at Atlassian, and it can be applied to any organization, whichever tools they use.
Learn more about the Loop.
Check out our pricing info and costs here.
Learn how to setup Atlas here. Users need to be added by the organization or site admin, learn more.
You can find ideas, tips, and best practices for using Atlas here.
Read our customer stories here.
Check out our downloadable Champion starter packs under the Guides section.
From inside Atlas - simply click the purple widget button in the bottom right corner and choose Help or Send us a message to get support.
From the Community - head over to the Atlas Product page and ask your question!
Daniella Latham
Product Marketing, AI for Work Management
Austin, TX
4 accepted answers
11 comments
