I have connected my Atlas project to a dedicated slack channel but the project update is posted to the slack channel. What step am I missing ?
I connected to a public slack channel. I did not see any setting within Atlas to configure any other permissions
Okay, try disconnecting and then reconnecting the Atlas project to that Slack channel. After that in Atlas, go to your project's settings and make sure that notifications for project updates are enabled. See if that works.
Thank you. Did that. Now I'll have to wait till the next weekly update to see if it works and posts to slack
All right. Please update this thread in case if it does not work. Here is a documentation from the community that might help in case if you want to review it again --> How to connect Atlas project with Slack.
