Is it feasible to generate a report that includes all comments from the project status update tab?
When i tried to do export of filtered projects, unfortunately, export offers only preview of dashboard on the front page, not the statuses from project itself.
Thank you in advance for your comments.
Unfortunately I do not believe this can be done where you get to see the update text. In the projects list you can see the status itself, but the list of fields to display as columns is fixed and does not include the latest update text. So you can see something is off-track, or at risk, but not why. Very frustrating.
Also I've been told that there is no API or JQL integration for Atlas, and no short term plans to do that, which is crazy given they are moving to integrate the tool into the core product. Because of this, I can have an issue (EPIC) in Jira, which is linked to an off-track status. But I can't report on the two, or show the linkage, or report the last status update. (without manually navigating into Atlas and finding that specific project, and opening it)
This is the single biggest weak point in Atlas in my opinion. If Atlassian were to provide even one of these, then it would be a simple process of filtering, or using an API to integrate reporting into Power Bi.
It feels like they are trying to differentiate by licence type. I am not that familiar with their enterprise offering, but I suspect it has some rolled-up reporting, and they would rather people pay for that than find that they can do mostly everything they want in Atlas.
I want to create a Monthly off-line project update report and I am struggling to see how can do that from Atlas without engaging in lots of copy/paste out of Atlas and into powerpoint. Do you have any approach that works in terms of rolling up reports out of Atlas? Thanks
