It is currently not possible to separate the status and scoring for targets in Atlas. The status “off-track” is automatically assigned for a scoring of 0.0 - 0.3, the status “at risk” for 0.4 - 0.7 and otherwise on-track.
Are there plans to make it possible to assign scoring and status separately in future, so that it will also be possible to map the combination of 0.6 and “off-track” or 0.2 and “on-track”, for example?
I'm able to do this
At least for Goals, haven't tried for Projects.
Yes, exactly. So 0.2 or 20% completed of the Goal may or may not be Off Track. What @Anna Kurpiela is saying is that it would be good to be able to say.... 0.2 - On Track. OR 0.2 Off Track.
e.g. if I'm in July and I've got through 20%, and it's progressing well for a Nov release, then that should show as 0.2 Green. But as it's currently set up it can ONLY show as red.
I think you are mixing some point of views :)
The state is In progress. Then you set "your best bet" on where are we when the time is out. It is not how much you have completed now but how much you expect to have completed when you are supposed to be finished.
