Is there a way to enable Atlassian Intelligence for custom fields?
Sanjeev Pande
November 27, 2023
Currently I am able to use Atlassian Intelligence prompts for generating content in description and comments fields. Is there a way I can enable it in a custom field?
3 comments
Tomasz Pośpiech
We identified a shortfall in Atlassian's offerings some time ago and have since developed a suitable tool that enables the addition of Custom Fields to your issues.
You have the option to select from a variety of Use Cases we've set up for automation. Decide on the source field for extracting text and the custom field where the result will be placed.
Additionally, you have the ability to manage the trigger, whether it's for creation or update.
At the moment, both the application and the use of tokens are free of charge.
Enjoy!
Look in the market place for AI Process Optimizer - Incident Management
Ethan Yew
December 1, 2023
Hi @Sanjeev Pande enabling Atlassian Intelligence for custom fields in Jira was not something we were looking to prioritise in the near term. However, I'm curious to better understand your intended use case for this! How would you leverage Atlassian Intelligence to generate and transform content in custom fields?
Shawn Doyle - ReleaseTEAM
Hi @Ethan Yew , I am Curious why custom fields were not done with the same priority as the standard fields?  We all use custom fields to collect specific data that is important to our projects, and being able to use AI on those fields is just if not more important than subject and description.
Todd Skelton
HI Ethan,
We have a custom Field called Resolution Description.  It would be fantastic to be ble to use AI to fill in the gaps.
Tomasz Pośpiech
@Todd Skelton I can arrange this for you. Please send me the details of your needs, including your input and the desired output. Our AI Process Optimizer app can handle it for you.
Paul Pasler
Hi @Sanjeev Pande ,
you may have a look at our #codegeist unleashed prototype, which brings two custom fields using AI: RefineMeFaster
We're also thinking about adding AI powered fields to our "main" project Awesome Custom Fields
So we're excited to hear your use cases :)
paul
