×I have a multi-select dropdown control 'Assignee' from the `Issue`.`Assignee Account ID` field used to filter my charts by adding this formula column to the Chart:
CASE WHEN {ASSIGNEE.IN('"Assignee"')} THEN 1 WHEN {ASSIGNEE} = "Unassigned" AND "Assignee account ID" is NULL then 1 ELSE 0 END
When a single value is selected in the control or the control is blank, the chart works as expected. But when the user selects multiple values in the control, the chart errors. Since I don't have a comma in my Custom Formula syntax, I'm assuming it is when the "ASSIGNEE.IN()" parsing multiple values. Help?
Warning
[SQLITE_ERROR] SQL error or missing database (near ",": syntax error)
Hey @Mark Dewes ,
Thank you for your question.
The issue appears to be with the second condition, "WHEN {ASSIGNEE} = 'Unassigned'". You're using a direct comparison for a multi-select field. While it works with a single value or an empty string, it will fail with multiple values because direct comparison doesn't apply in those cases.
Instead, you can remove this condition and simply use "Assignee account ID IS NULL" to cover any unassigned situations. Please try this approach and feel free to ask if you have any questions.
Arumugam
