How to create a chart setting text field
Mikel Whipple
I used a template to create a dashboard but these fields above the control I cannot figure out how to create more of them since I am going to be adding more controls. They are just built as Chart Settings. Any help is appreciated. 2025-03-21_06-31-51.jpg 2025-03-21_06-32-09.jpg 2025-03-21_06-32-21.jpg
Arumugam M
March 24, 2025
Hey @Mikel Whipple ,
Thank you for your questions.
To add more controls to the dashboard, Select Add Control from sidebar on the right side and choose the type of control you want and place the newly added control on the dashboard.
I'm attaching some screenshots for your reference:
You can learn more about these in the link below;
https://support.atlassian.com/analytics/docs/set-up-a-dropdown-control/
Arumugam
Mark Dewes
March 25, 2025
The templates use something called a "Chart Setting" object that allows the user to create Labels or formatted explanations within the dashboard. These are not Controls that I know of. I am wondering the same question. How can I create a "Chart Setting" object in my user-created dashboard?
Like Mikel Whipple likes this
