How we can migrate Azure Test suites in Jira Test repository .
How we can migrate Azure Test suites in Jira Test repository.
2 comments
Radoslaw Cichocki {Deviniti}
Hi @prajakta_desai
You will need to
  1. Export your test cases to CSV (link)
  2. Change the data format in the CSV to one suited to the importer of a Jira test management app of your choice
    1. note: Jira alone does not support test management very well, but there are many apps that solve this
  3. Import the data to the Jira app
Since I represent Deviniti, I would like to recommend our Requirements & Test Management for Jira.
Here's how to import test cases to RTM.
If you have questions about the import, I encourage you to contact our support.
Radek Cichocki
Head of Atlassian Apps @ Deviniti
Like Rajesh Viswanathan likes this
Nina Zaradniak_Deviniti_
Hi @Rocio Katsanis
Did you manage to resolve the import issue or do you still need help?
Cheers, Nina.
