How to fetch users present in Auth Policy?
Balachandra Bhat November 21, 2024
I was able to follow the below api to add users to SSO authentication policy from normal default local policy - Applies to All users.
Cookbook for authentication policy
Is there any api url to get the list of users present in SSO authentication policy and normal default local policy - Applies to All users. ?
2 comments
Darryl Lee
Oh hi @Balachandra Bhat !
So ... certain people might not like it but... there's an unofficial, undocumented API for this (meaning that YOU SHOULD NOT use this for any production automations, but for one-off admin type of tasks, it's probably fine).
https://admin.atlassian.com/gateway/api/admin/private/org/{ORGANIZATION_ID}/auth-policy/{AUTHENTICATION_POLICY_ID}/users?first=100&offset=0
So the default number displayed in the UI was 20 (the first parameter), and I wasn't able to bump that up higher than 100. Anywho, I was able to keep bumping the offset up by 100 to get the next page of results. This endpoint returns a handy "totalUsers" value as well as a "hasNextPage" so you know when to stop.
How can you find {ORGANIZATION_ID} and {AUTHENTICATION_POLICY_ID}?
Welp, if you click into one of your Policies, it should be right there in the URL:
https://admin.atlassian.com/o/{ORGANIZATION_ID}/authentication-policies/policy/{AUTHENTICATION_POLICY_ID}
Have fun!
Like # people like this
Balachandra Bhat November 22, 2024
@Darryl Lee  Thanks for sharing the endpoint url.  Could you please provide the more information like operation type get or post or patch call. What should be the Auth type?
I did a get call and used the Bearer token which I was using for adding users to SSO auth policy and I got Unauthorized error with response code of 401.
Darryl Lee
Oh man, that is a great question @Balachandra Bhat and I was absolutely negligent in providing that info.
I was hitting that URL from my browser session.
So unfortunately like other unofficial (and "private") APIs, this one doesn't appear to have an external authentication method like Bearer or Basic (token).
(I tried my personal token, for an account which has Org Admin rights, and it also failed with a 401.)
SO THEN, what does work?
One of the nastiest hackiest things you can do! Session Cookies.
I went through all the cookies my browser was sending, and isolated the one cookie that was actually required: feeding the cloud.session.token to curl worked, like so:
curl 'https://admin.atlassian.com/gateway/api/admin/private/org/{ORGANIZATION_ID}/auth-policy/{AUTHENTICATION_POLICY_ID}/users?first=100&offset=0' -H 'cookie: cloud.session.token=YOURCLOUDSESSIONTOKENFROMYOURBROWSER'
Like I should have said from the beginning. THIS IS A HACK. (And so am I.) :-}
Darryl Lee
You might be wondering how long that session token will last. According to the one I generated today, about one month:
admin.atlassian.com FALSE   /   TRUE    1734888282  cloud.session.token MYCLOUDSESSIONTOKEN
That's Sun Dec 22 09:24:42 PST 2024.
I have not tried to programmatically generate a cloud.session.token.
People have asked about this before, and well, I'm 100% with @federico on this:
The REST APIs are very incomplete for people using JIRA and BITBUCKET. All is supposedly connected together, yet those API do not provide any meaningful way to play with the fact that we use JIRA and BITBUCKET.
There are countless thread about it but yet still gathering interest and beeing answered by please use internal API but we don't support it.
This is not a viable solution, but it is recommended so much that at some point I am wondering...
So yes, I should not do it, but there is no alternative and Atlassian team tell us to use it while not recommending it for so basic feature as "get jira issue from bitbucket PR" or "get PR from Jira Issue"
So yes your answer is correct and simple. But then I am open to other suggestion than using this internal api
Harrison Ponce
November 22, 2024
Darryl Lee
@Harrison Ponce I literally LOLed. YUP. It's AWFUL.
If you have a script or something you ABSOLUTELY should only be storing and running it from YOUR LAPTOP.
Kshitij Nirgude March 21, 2025
Till a few months back we were able to pass "cloud.session.token" cookie with our rest api calls and calls were getting authenticated, although the cookie based auth deprecation notice is there since 2019. However the rest apis authentication using "cloud.session.token" stopped recently for us? Can you please let us know when did this exactly get removed (approx month/year)
Darryl Lee
Ah, the question is which REST API calls are you making? And where was this notice about cookie based auth being deprecated?
I mean, they were never supported in the first place, because they're STRICTLY for use in an actual Web Browser. :-}
As @Harrison Ponce rightly points out, using session cookies is a horrible idea.
And yet. Since Atlassian does not have a public or (private API that works with Organization API Keys) for operations like this exact one (list of users in Auth Policy), what are we supposed to do? Copy and paste?
Nah.
(BTW, these opinions are MINE alone. I do not work for Atlassian.)
