Hi Team, Good Day!!.
In Anguar I'm trying to update Jira sub task status update using transitions - api/2/issue/JJIRAidorKEY/transitions with POST request. but the response gives XSRF checked failed. statusCode: 403.
Im able to fetch Jira Data using GET request.. this is first time Im using POSt request to update "name":"In Progress" to "Done.
"update": {
"subtasks": [
"fields": {
"status":{
"statusCategory":{
"transition": {
"id": "31"
Pls suggest if we you know any other approach in angular.
Your help is appreciated!!
Community moderators have prevented the ability to post new answers.
Not sure whether it's related, but I do know that for POST and PUT request you need to add this header:
{'Content-Type': 'application/json'}
This is in addition to the header needed in all Jira REST-API requests:
{'Accept': 'application/json'}
You can't just update the name. You must execute the transition. Even not the status category. You need to mention the new status I think. But I don't have the documentation in mind.
