💡 FAQs and things to know before you get started!
Things to know before you get started
Data permissions
The data that you see on your Atlassian Home dashboards comes from the Atlassian Data Lake and aggregates data across your products. It is not refined by a JQL-backed saved filter or Jira board. You will need to use dashboard-level filters to refine the scope of data.
The data presented in these charts do respect object-level permissions, so the data you see may differ from what one of your team members sees. For example, if you create a chart that shows a count of issues by status and share it with a team member, you both may see different counts depending on the permissions of individual issues in your project.
Dashboard permissions
There are three permission levels for dashboards:
  • can view
  • can edit
  • can manage
The following dashboard actions are available per permission level:
Action
Can view
Can edit
Can manage
View charts
Yes
Yes
Yes
Interact with dashboard-level filters
Yes
Yes
Yes
Refresh chart or dashboard data
Yes
Yes
Yes
Create new charts
No
Yes
Yes
Edit existing charts
No
Yes
Yes
Grant or revoke access to the dashboard
No
No
Yes
Copy dashboard
Yes
Yes
Yes
Delete dashboard
No
No
Yes
Data and metrics support
Today we support four metrics, which determine the numerical values in your chart:
  • Issue count - count of Jira issues that match the selected categories and filters.
  • Story point sum - sum of story points that match the selected categories and filters.
  • Average lead time - the amount of time between when work on an issue started (moved to an "In progress" status) to when the work was completed (moved to a "Done" status).
  • Average issue age - the amount of time between when an issue was created and now.
We plan to expand this to include data from across your Atlassian products, including DevOps, Jira Service Management, Confluence, and Atlas.
Dashboard-level filters
We recommend that you first set up a few dashboard-level filters before you create any charts. This will help refine the data that appears on your charts. Try to filter on key projects or issue types that you're most interested in.
This will improve performance and help you better understand the charts that you're looking at on the dashboard.
FAQs
I think I have run into a bug. What should I do?
  • Use our in-product chat in the bottom-right corner to get in touch with our team. Try to share as much context as possible, including screenshots or screen recordings of the bug. This will help us troubleshoot more quickly.
  • Alternatively, create a new post in this Community group by using the Ask a question button at the top of the group page.
I would like to exit the alpha program. How can I do that?
  • Use our in-product chat in the bottom-right corner to get in touch with our team. Simply let us know you're no longer interested in being a part of the alpha program, and we'll remove the feature from your Atlassian Home instance.
I’d like to give feedback. How should I do it?
  • Use our in-product chat in the bottom-right corner to get in touch with our team. We’d love to hear your feedback on missing features and potential enhancements.
How can I share my dashboards with others on my team?
Today, there's only one way to share the dashboard with others in your organization:
  1. Navigate to the Dashboards tab in Atlassian Home.
  2. Select More actions (three-dot menu) for the dashboard you want to share.
  3. Select Grant access. A pop-up will appear where you can grant view, edit, or manage permission to individual users or groups.
Note: There’s currently no way to view who has been given access to the dashboard or to revoke access to the dashboard without deleting it.
0 comments
