Sign up Log in
Has the linking to Jira Epics functionality happened?
Curt Holley
June 13, 2022
I see it is hyped here: Atlas | The Teamwork Directory every company needs (atlassian.com)
But other than embedding a link into the epic, I can't see how any deeper linking can be done (on Cloud...for the record).
2 accepted
Rachel Lin
June 20, 2022
Hey Curt, thanks for your question. We are working on releasing the Jira integration at the moment. We are exploring a flow to connect from Atlas to Jira and we'd love to get some feedback on what we've built. Would you be able to spend 30 mins with us to get a sneak peek of how the integration works and share your thoughts?
Please feel free to find 30m on my Calendly so we can chat: https://calendly.com/rlin2/30min
Majken Longlade
If you're looking for more feedback, we'd be interested!
Like Sherif Mansour likes this
Rachel Lin
June 21, 2022
Hi @Majken Longlade
Please find some time in my calendly link above for next week! :)
Michelle Grady
Would like to provide some feedback as well, it's one the pieces that would help fully adopt this feature for our team. I was found some time in your calendar next week.
Stephen.Marsh July 21, 2022
hey @Rachel Lin if you are still seeking feedback, please let me know and i'll stick 30mins in. Regards, Stephen
David Nadri
September 13, 2022
@Rachel Lin @Sherif Mansour - how could I schedule a time to get a sneak peek of how the integration works and provide feedback please?
Sherif Mansour
September 13, 2022 edited
@David Nadri her is a sneak peak video of the upcoming Atlas ← → Jira Software integration
Like David Nadri likes this
Rachel Lin
September 14, 2022 edited
Hi everyone! Rachel from Atlas here 👋 I wanted to circle back on this feedback to let you know that we announced the release of our Atlas for Jira Cloud integration. You will be able to use it to link an Atlas project with a Jira software epic and sync core details like title, dates and tags between the two.
To learn more detail about how to install the integration on Jira and how it works, check out this article.
As a refresher to how we perceive the relationship between Jira and Atlas, read here.
Thank you so much for your patience and feedback. We can't wait to see you using the Atlas for Jira Cloud integration and hear what you think of it. Have a great day!
Tom Hedges
November 30, 2022
Hi @Rachel Lin , I've tried to set up a link between Atlas and Jira, using the Atlas for Jira Cloud integration, however I am not seeing the ability to connect the two applications, or the additional fields in Jira.
Are there any additional settings I need to adjust or subscriptions I need in order to link the two applications together?
Thank you!
Rachel Lin
November 30, 2022
Hi Tom! Hopefully I can help you out here :)
Once you've installed the Atlas for Jira integration to your Jira site, it should automatically be appearing on issues.
Things to check:
- Is the issue an EPIC that you are trying to connect?
- See if you expand the right hand panel on an issue, the app field should be near the bottom labelled "Share updates about this work"
- Try pasting the Jira epic link from the Atlas project side, under the "Work Tracking" field. You should be prompted with a "Sync this project" option.
Let me know if any of those work.
Sherif Mansour
June 19, 2022
Coming very soon, @Rachel Lin and team are working on it -- she can provide an update.
Sherif
Oliver Wemyss
@Rachel Lin , will this work with other issue types above the Epic? Higher level goals and projects can be tracked as initiatives or other names as parents to epics. Will this functionality scale upwards for teams building on top of advanced roadmaps to multiple levels?
Praveen
Hi, is this rolled out now, we are testing this and would like to try the integration too.
Upcoming Atlassian Home Events
