AI footprints on a Jira item? - Is it reportable?
benbaumann
January 13, 2025
Is there any footprints on a Jira epic, story, bug, spike, subtask.... that can tell you that Atlassian Intelligence was used on the item?  I would like to be able to write a filter showing which items have used AI and attempt to quantify the value.
1 comment
Anahit Sukiasyan
Hi @benbaumann
Welcome to the Community!
If I'm not mistaken, currently, Atlassian Intelligence features, such as those for generating summaries or automating actions, do not leave a direct, visible footprint in Jira issues that can be easily queried via JQL.
benbaumann
January 16, 2025
As far as I could tell you're right.  It makes things really difficult to quantify the value the AI tool is adding, which would enable a proper business decision on if it's worth rolling out.  I would like to see this addressed by Atlassian.
Like • Anahit Sukiasyan likes this
Anahit Sukiasyan
I completely agree-it’s challenging to measure the impact of Atlassian Intelligence without a way to track its usage. If Atlassian provided a way to log AI interactions, it would make it much easier to quantify its value. It’s a feature worth suggesting to Atlassian directly!
