Hi there!
I'm looking for an option to set visibility restrictions/permissions to custom fields in Jira. Do you think it's possible to realize that or does maybe someone of you know another workaround to realize that functionality?
Use Case is that we would like to use custom fields for ROI or investment and therefore these fields should not be visible to everyone.
I'm looking forward to opinions and answers.
Jira does not have field-level security (it's a collaborative anti-pattern).
There are a couple of apps that provide them in the marketplace which are worth a look (they do work well in my experience)
For your use case, did you try Team managed projects?
Refer: available-custom-fields-for-team-managed-projects
Fields in team-managed projects are contained within the project itself. Currently, you can't share a field created in one team-managed project with another team-managed project, or with a company-managed project. Similarly, you can't use a custom field created in a company-managed project on your team-managed project issues.
NOTE: Restrict the project access level to private.
Also, just FYI Atlassian has in scope to share team-managed projects configuration in future.
Kind Regards
Utkarsh
