Sign up Log in
Project Configurator vs. Configuration Manager for Jira: Which is the Best Fit for You?
Gregory Kneller
I’ve put together a detailed comparison of Project Configurator for Jira and Configuration Manager for Jira (focused on Data Center) based on their features, strengths, and use cases. These tools are widely used for migrations, configuration management, and administration, but they cater to slightly different needs.
For instance:
  • Configuration Manager seems ideal for enterprise-level tasks like full instance migrations, staging-to-production syncs, or merging multiple Jira instances.
  • On the other hand, Project Configurator is better suited for granular project-level changes, like exporting/importing workflows or smaller migrations.
What I’d love to know is:
  1. Do these points align with your experience?
    • For example, how do you handle Cloud migrations, or do you find one tool better suited for specific staging-production syncs?
  2. Would you argue any of these points?
    • Are there features of either tool that you think are under- or over-represented here?
  3. Which tool has worked better for your specific use cases?
    • Have you found one of these tools easier to use, more reliable, or better for scaling large instances?
I’d appreciate your thoughts, experiences, and opinions—especially if you’ve worked with either of these tools in enterprise or complex Jira environments. Let’s collaborate and build a clearer picture of how these tools stack up!
Looking forward to your insights! 🚀
AspectConfiguration Manager for JiraProject Configurator for Jira
Main FocusEnterprise-level configuration and partial data migrations.Project-level migrations and granular configuration export/import.
Primary Use CaseComplex migrations, instance consolidation, and staging-production syncs.Granular project migrations and targeted project-level configuration changes.
Instance MigrationsSupports full instance migrations, including data integrity checks.Not designed for full instance migrations; focuses on project-level changes.
Project-Level MigrationsHandles project migrations, including dependencies (workflows, fields, etc.).Specializes in project migrations, making it ideal for granular changes.
Cross-Instance CompatibilityValidates compatibility between source and target instances automatically.Provides compatibility checks but may require manual intervention for conflicts.
Cloud Migration SupportPartial support for Cloud migrations with enhanced configuration mapping.Partial Cloud support but requires more manual steps for configuration mapping.
Centralized ConfigurationIdeal for standardizing configurations across multiple environments (e.g., staging, testing, production).Focused on project-specific configuration changes.
Version ControlOffers built-in configuration versioning with rollback capabilities.No built-in version control; XML files can be saved and re-imported.
Comparing ConfigurationsAllows detailed comparison between projects or instances to detect inconsistencies.Does not provide direct comparison tools but changes can be reviewed during import/export.
UsabilityTailored for enterprise administrators managing complex setups.Simpler interface, easier for project-focused admins.
Granularity of ChangesInstance-wide changes and deep configuration management for large-scale systems.Granular changes for project-level configurations.
ValidationPerforms pre-flight validation for compatibility issues, reducing migration risks.Basic validation during export/import but less detailed than Configuration Manager.
Reporting and Audit TrailsIncludes audit trails and detailed reports for configuration changes and compatibility checks.Limited reporting; provides basic logs for export/import processes.
Merging Multiple InstancesIdeal for consolidating multiple Jira instances into one.Limited support for instance merging; project-focused.
Staging and Production SyncExcellent for syncing configurations between environments.Limited to exporting/importing specific project configurations.
Enterprise ScalabilityBest suited for large enterprises with many projects, fields, and workflows.Better suited for smaller setups or project-focused migrations.
2 comments
Shah_ Piyush
These are both 3rd party paid plugins and cost can be out of control if you have large user base.  Yes, the version control part is helpful. I hope Atlassian features for JCMA, C2C and X2C will catch up one day so we don't need to spend $$ on plugins.
Kelsey LaMastres _Appfire_
Hi Gregory,
Kelsey from Appfire here, the vendor behind both Configuration Manager for Jira (CMJ) and Project Configurator for Jira (PCJ). Thanks for posing this question to the community! I’m curious to follow along with the responses that come in. In the meantime, I wanted to share some insights from our product team.
CMJ and PCJ address similar use cases, but our product team will be focusing future development on CMJ to improve user experience and processes. We’ll continue to support PCJ with maintenance updates and technical help, but we won’t be adding new features.
Here are a few key benefits of using CMJ:
  • Faster import speeds: Get your data migrated quickly.
  • In-app safeguards: Reduce errors during deployments with built-in protections.
  • Third-party app support: CMJ works with over 40 apps to support complex migrations.
  • Cloud-ready: CMJ offers a growing cloud version, unlike PCJ. If you’re planning for cloud, CMJ will meet those needs.
You can visit our resource page to learn more. If you have any questions, feel free to reach out to our support team
Hope this helps!
-Kelsey
Register Now
