There was a problem configuring the database for import.
Sean McConnell
This is the Error, I received and am not certain how to resolve the issue.
There was a problem configuring the database for import. Please contact Atlassian support. Caught PSQLException for select 1 from "public"."cwd_user" "CWD_USER" where "CWD_USER"."id" in (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) FOR UPDATE OF "CWD_USER"
Rui Zhang
November 14, 2021
Hi @Sean McConnell , I have the same issue while migrating Jira using site import. Have you found any solution on this issue?
Ivan Krastev
June 4, 2021
Any solution here? Got the same error during importing data into cloud instance.
Mahmoud Ali
October 29, 2021
@Ivan Krastev did you figure out the root cause? I'm running into the same issue while importing the data into the Cloud. Thanks!
Sri Kumar
December 21, 2020
Hi @Sean McConnell
It looks like the import is failing when it tries to update the user entries on the database of the cloud during the Import.
We recommend you to reach our the Atlassian Migration support and we can help you with further troubleshooting the issue and migrate successfully.
-Sri
Nic Brough -Adaptavist-
November 25, 2020
Where are you getting this?  You've said "atlassian cloud migration", but that's an error I would only expect to see in a Server log file.  Could you give us all the steps to reproduce this?
