How to access Hamlet and Gateway APIs (invoice, available-products)?
Leo Nguyen
August 6, 2025
Hi Atlassian team / community,
I'm currently trying to access some APIs that appear to be private or internal. Specifically:
  1. GET https://www.atlassian.com/hamlet/1.0/public/order/{orderId}/summary
    → Seems to return invoice/order summary info. I get a 401Unauthorized error.
  2. GET https://www.atlassian.com/gateway/api/available-products/api/available-products
    → Appears to list available products for a site. I cannot access it.
  3. GET https://www.atlassian.com/hamlet/1.0/public/order/external/invoice/{orderId}/pdf
    → I assume this returns a PDF invoice file. Also blocked or inaccessible.
My questions:
  • Are these APIs publicly accessible, or are they meant to be internal-only?
  • Is there any documentation for them?
  • What authentication method is required (e.g. OAuth scopes, Forge token, admin cookies)?
  • Are there public alternatives for accessing billing data and available products?
Notes:
  • I tested with Postman using admin session cookies.
  • I couldn't find any mention of these endpoints on developer.atlassian.com.
Thanks in advance for any clarification or official guidance!
SMS
August 7, 2025
Hi @Leo Nguyen,
Good day, and welcome to Atlassian Community! I'm Shannon, with the Community Support team.
The API endpoints you're referring to are for internal use only, but I found there's a Commerce API you can use. You can authenticate with an Atlassian API token.
If you find what you need isn't here, we are looking into into the possibility of adding a more comprehensive billing API:
  • COMMERCE-25  Ability to retrieve comprehensive billing information via REST API
You can add a comment to that feature sharing with our product team your use case and what you need the API to accomplish.
I hope this helps but let me know if you have any further questions!
Shannon S | Atlassian Community Support
