Using MCP, how do you Link two tickets together (creation or edit)
Mark Progano
July 10, 2025
Has anyone else has problem/success with this...
I've asked the LLM a few ways in a few direction to connect one ticket to another, both on edit and creation. I keep seeing a rejection around formatting in the MCP logs.
What do I need to tell the LLM so it knows how to link it? what fields should it be using on create/edit?
*Note: I am using the official MCP server, which can do everything else including custom fields with tickets :(
Utkarsh Agarwal
July 21, 2025
Hi @Mark Progano
Welcome to the community!
Linking issues via MCP can be tricky because the official Remote MCP Server currently doesn’t abstract Jira’s link field – it relies on the standard Jira REST API fields. When creating or editing, you need to instruct the LLM to populate the issuelinks field explicitly, including the link type and inward/outward issue keys (e.g., blocks, relates to).
Example JSON the LLM should generate:
"issuelinks": [
"type": { "name": "Blocks" },
"outwardIssue": { "key": "ABC-123" }
For multiple links, repeat the objects in the array.
This has worked for others in similar tests; you may need to guide the LLM with “link this issue as Blocks ABC‑123” or similar phrasing.
You can also refer to Atlassian’s MCP article here: Using the Atlassian Remote MCP Server.
Hope that helps!
Kind Regards
Utkarsh
Mark Progano
July 23, 2025
Thank you, it'd be very helpful if the AI knew that. Maybe clearer docs would help?
