Hello Guys,
I want to adapt my plugin to be compatible with JIRA 7, so, I updated
jira.version and amps version inside my pom.xml:
<?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>com.murex.crm.autotransition</groupId> <artifactId>crm-auto-transition</artifactId> <version>1.0</version> <organization> <name>Murex</name> <url>http://www.murex.com/</url> </organization> <name>Murex Auto-Transition</name> <description>This plugin allows triggering a transition after the current one is being executed, based on certain condition.</description> <packaging>atlassian-plugin</packaging> <dependencies> <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-api</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> <!-- <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-core</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> --> <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.10</version> <scope>test</scope> </dependency> <!-- WIRED TEST RUNNER DEPENDENCIES --> <dependency> <groupId>com.atlassian.plugins</groupId> <artifactId>atlassian-plugins-osgi-testrunner</artifactId> <version>${plugin.testrunner.version}</version> <scope>test</scope> </dependency> <dependency> <groupId>javax.ws.rs</groupId> <artifactId>jsr311-api</artifactId> <version>1.1.1</version> <scope>provided</scope> </dependency> <dependency> <groupId>com.google.code.gson</groupId> <artifactId>gson</artifactId> <version>2.2.2-atlassian-1</version> <scope>provided</scope> </dependency> <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-api</artifactId> <version>1.6.6</version> <scope>provided</scope> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-beans</artifactId> <version>2.5.6.SEC03</version> <scope>provided</scope> </dependency> <!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit --> <!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit --> <!-- <dependency> <groupId>com.atlassian.jira.tests</groupId> <artifactId>jira-testkit-client</artifactId> <version>${testkit.version}</version> <scope>test</scope> </dependency> --> <dependency> <groupId>org.mockito</groupId> <artifactId>mockito-all</artifactId> <version>1.8.5</version> <scope>test</scope> </dependency> </dependencies> <build> <plugins> <plugin> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-amps-plugin</artifactId> <version>${amps.version}</version> <extensions>true</extensions> </plugin> <plugin> <artifactId>maven-compiler-plugin</artifactId> <configuration> <source>1.6</source> <target>1.6</target> </configuration> </plugin> </plugins> </build> <properties> <jira.version>7.0.0</jira.version> <amps.version>6.2.1</amps.version> <plugin.testrunner.version>1.1.4</plugin.testrunner.version> <!-- TestKit version 5.x for JIRA 5.x, 6.x for JIRA 6.x --> <testkit.version>5.2.26</testkit.version> </properties> </project>
But, when I run atlas-mvn eclipse:eclipse, I encountered the following error:
Can you please help?
Did I miss something?
Many thanks,
Rosy
