could you recommend any solution or partner that provides this solution : Copy data from jira to AWS
Hi Francisco,Jira Data Center in AWS? or what are you using the data for in what AWS product?RegardsCJ
Hi Francisco,
Copy Means whether you need to migrate jira to AWS or what?
Please take the export dump from on-prem ORacle or whatever DB and copy to s3 bucket using awscli and then copy it to RDS Oracle server.
import it using RDSs3 utility.
in case of attachemnets ,pls follow the same
on prem >> s3 >> efs
francisco.gomes
Data Analyst
5 total posts
3 comments
