Sign up Log in
Moving Artifacts
This script helps to move artifacts from one location to another without overwriting any file.
  • Compatible with Python 2.7+
  • Moves artifacts from an old location STALE_ARTIFACT_DIRECTORY to a new location ARTIFACT_DIRECTORY
  • Only moves the artifact which doesn't exist in the ARTIFACT_DIRECTORY to avoid overwriting artifacts
import os, shutil, re
STALE_ARTIFACT_DIRECTORY = "/home/user/atlassian-home/artifacts/" # Path to the Home directory artifacts
ARTIFACT_DIRECTORY = "/home/user/atlassian-home/shared/artifacts" # Path to Shared directory artifact
list_of_migrated_artifacts =[]
# If the path to an artifact location does not exist in {BAMBOO-HOME}/shared directory but exist {BAMBOO-HOME}/artifact directory, we consider it as an artifact that needs to be moved
def is_artifacts_present_in_current_plans(storage_tag='',plan_artifact='', type=''):
    # Construct a path to Bamboo artifact storage in plan storag tag
    storage_path = '{0}/{1}/{2}'.format(ARTIFACT_DIRECTORY,storage_tag,type)
    if os.path.exists(storage_path):
        # check if artifact exist in the path
        artifact_path = '{0}/{1}/{2}/{3}'.format(ARTIFACT_DIRECTORY,storage_tag,type,plan_artifact)
        stale_artifact_path = '{0}{1}/{2}/{3}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag,type,plan_artifact)
        # If the artifact exist in {BAMBOO-HOME}/shared directory, do nothing
        if os.path.exists(artifact_path):
            x = None
        else:
            shutil.move(stale_artifact_path,storage_path)
            result = {"Moved": stale_artifact_path, "to":storage_path}
            list_of_migrated_artifacts.append(result)
    else:
        stale_plan_storage= '{0}{1}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag)
        main_plan_storage = '{0}/{1}'.format(ARTIFACT_DIRECTORY,storage_tag)
        # Move the storage path and all its directories to {BAMBOO-HOME}/shared/artifacts/...
        if not os.path.exists(main_plan_storage):
            tmp_stale_storage = '{0}{1}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag)
            tmp_main_plan_storage = '{0}/{1}'.format(ARTIFACT_DIRECTORY,storage_tag)
            shutil.move(tmp_stale_storage,tmp_main_plan_storage)
            result = {"Moved":tmp_stale_storage, "to":tmp_main_plan_storage}
        else:
            _tmp_stale_storage = '{0}{1}/{2}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag,type)
            shutil.move(_tmp_stale_storage,tmp_main_plan_storage)
            result = {"Moved":_tmp_stale_storage,"to":tmp_main_plan_storage}
    return
def prepare_artifacts_directories():
    try:
        for storage_tag in os.listdir(STALE_ARTIFACT_DIRECTORY): # list all storage tags in artifact directory # {storage_tag}
            storage_path = os.path.join(STALE_ARTIFACT_DIRECTORY, storage_tag) # create a path to the storage tags /Users/voseghale/atlassian-home/bamboo803/artifacts/{storage_tag}
            if os.path.isdir(storage_path):
                for x in os.listdir(storage_path): # get all shared and none shared artifacts
                    is_shared_artifacts = re.match(r'shared',x)
                    if is_shared_artifacts:
                        # Get all shared artifacts
                        shared_artifact_path = os.path.join(storage_path,x) # create the path to shared
                        if os.path.isdir(shared_artifact_path):
                            for artifact_ in os.listdir(shared_artifact_path): # list each artifact in a shared path
                                path_to_each_artifact = os.path.join(shared_artifact_path,artifact_)
                                if os.path.isdir(path_to_each_artifact):
                                    result = is_artifacts_present_in_current_plans(storage_tag=storage_tag,plan_artifact=artifact_, type=x)
                    else:
                        # Get all none shared artifacts
                        share_artifact_path = os.path.join(storage_path,x) # create the path to shared
                        if os.path.isdir(share_artifact_path):
                            for artifact_ in os.listdir(share_artifact_path): # list each artifact in a shared path
                                path_to_each_artifact = os.path.join(share_artifact_path,artifact_)
        print("---- Artifacts Copied ----")
        print(list_of_migrated_artifacts)
    except FileNotFoundError as err:
        print(err)
    return
if __name__== "__main__":
1 comment
Danwin Ambros-Francis
June 6, 2023
Great script @VICTOR-OSEGHALE it helped a ton to resolve our issue!
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Bamboo Events
