Sign up Log in
Moving Artifacts
This script helps to move artifacts from one location to another without overwriting any file.
  • Compatible with Python 2.7+
  • Moves artifacts from an old location STALE_ARTIFACT_DIRECTORY to a new location ARTIFACT_DIRECTORY
  • Only moves the artifact which doesn't exist in the ARTIFACT_DIRECTORY to avoid overwriting artifacts
import os, shutil, re
STALE_ARTIFACT_DIRECTORY = "/home/user/atlassian-home/artifacts/" # Path to the Home directory artifacts
ARTIFACT_DIRECTORY = "/home/user/atlassian-home/shared/artifacts" # Path to Shared directory artifact
list_of_migrated_artifacts =[]
# If the path to an artifact location does not exist in {BAMBOO-HOME}/shared directory but exist {BAMBOO-HOME}/artifact directory, we consider it as an artifact that needs to be moved
def is_artifacts_present_in_current_plans(storage_tag='',plan_artifact='', type=''):
    # Construct a path to Bamboo artifact storage in plan storag tag
    storage_path = '{0}/{1}/{2}'.format(ARTIFACT_DIRECTORY,storage_tag,type)
    if os.path.exists(storage_path):
        # check if artifact exist in the path
        artifact_path = '{0}/{1}/{2}/{3}'.format(ARTIFACT_DIRECTORY,storage_tag,type,plan_artifact)
        stale_artifact_path = '{0}{1}/{2}/{3}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag,type,plan_artifact)
        # If the artifact exist in {BAMBOO-HOME}/shared directory, do nothing
        if os.path.exists(artifact_path):
            x = None
        else:
            shutil.move(stale_artifact_path,storage_path)
            result = {"Moved": stale_artifact_path, "to":storage_path}
            list_of_migrated_artifacts.append(result)
    else:
        stale_plan_storage= '{0}{1}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag)
        main_plan_storage = '{0}/{1}'.format(ARTIFACT_DIRECTORY,storage_tag)
        # Move the storage path and all its directories to {BAMBOO-HOME}/shared/artifacts/...
        if not os.path.exists(main_plan_storage):
            tmp_stale_storage = '{0}{1}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag)
            tmp_main_plan_storage = '{0}/{1}'.format(ARTIFACT_DIRECTORY,storage_tag)
            shutil.move(tmp_stale_storage,tmp_main_plan_storage)
            result = {"Moved":tmp_stale_storage, "to":tmp_main_plan_storage}
        else:
            _tmp_stale_storage = '{0}{1}/{2}'.format(STALE_ARTIFACT_DIRECTORY,storage_tag,type)
            shutil.move(_tmp_stale_storage,tmp_main_plan_storage)
            result = {"Moved":_tmp_stale_storage,"to":tmp_main_plan_storage}
    return
def prepare_artifacts_directories():
    try:
        for storage_tag in os.listdir(STALE_ARTIFACT_DIRECTORY): # list all storage tags in artifact directory # {storage_tag}
            storage_path = os.path.join(STALE_ARTIFACT_DIRECTORY, storage_tag) # create a path to the storage tags /Users/voseghale/atlassian-home/bamboo803/artifacts/{storage_tag}
            if os.path.isdir(storage_path):
                for x in os.listdir(storage_path): # get all shared and none shared artifacts
                    is_shared_artifacts = re.match(r'shared',x)
                    if is_shared_artifacts:
                        # Get all shared artifacts
                        shared_artifact_path = os.path.join(storage_path,x) # create the path to shared
                        if os.path.isdir(shared_artifact_path):
                            for artifact_ in os.listdir(shared_artifact_path): # list each artifact in a shared path
                                path_to_each_artifact = os.path.join(shared_artifact_path,artifact_)
                                if os.path.isdir(path_to_each_artifact):
                                    result = is_artifacts_present_in_current_plans(storage_tag=storage_tag,plan_artifact=artifact_, type=x)
                    else:
                        # Get all none shared artifacts
                        share_artifact_path = os.path.join(storage_path,x) # create the path to shared
                        if os.path.isdir(share_artifact_path):
                            for artifact_ in os.listdir(share_artifact_path): # list each artifact in a shared path
                                path_to_each_artifact = os.path.join(share_artifact_path,artifact_)
        print("---- Artifacts Copied ----")
        print(list_of_migrated_artifacts)
    except FileNotFoundError as err:
        print(err)
    return
if __name__== "__main__":
1 comment
Danwin Ambros-Francis
June 6, 2023
Great script @VICTOR-OSEGHALE it helped a ton to resolve our issue!
Upcoming Bamboo Events
