ANT_HOME being overridden on Bamboo Remote Agent
Ryan Schaaf
Having a weird issue with my Bamboo Remote Agents and ANT_HOME. The TL;DR - Is I have ANT_HOME set for the shell executing the remote agent, however bamboo appears to be overriding it with its own value when executing the ANT task:
The Configuration:
 > Bamboo Instance on an Amazon Linux EC2
 > Bamboo Remote Agent on Amazon Linux EC2
     > ant installed via AWS yum repo ( yum -y install ant )
The ant executable is installed in /usr/bin/ant , however the etc and lib directories are in /usr/share/ant.
I installed the remote agent using an init.d wrapper, which looks like this:
#!/bin/bash
# Wrapper script to execute the Bamboo Remote Agent
# that lives at /opt/atlassian/application-data/bamboo-agent/bin/bamboo-agent.sh
# chkconfig: 2345 20 80
# description: Bamboo Remote Agent Wrapper
export RUN_AS_USER=bamboo
export ANT_HOME=/usr/share/ant/
export JAVA_HOME=/usr/lib/jvm/jre-1.8.0-openjdk.x86_64/
export BAMBOO_HOME=/opt/atlassian/bamboo/
exec "/opt/atlassian/application-data/bamboo-agent/bin/bamboo-agent.sh" "$@"
The agent launches and connects successfully. When trying to build using the Ant Task, we get the "Your ANT_HOME isn't set correctly" error of:
error	13-Aug-2018 14:04:04	Error: Could not find or load main class org.apache.tools.ant.launch.Launcher
I embedded a shell task to verify that the ANT_HOME is set in the wrapper of just
    > echo Ant Home: ${ANT_HOME}
And in the logs I see
build	13-Aug-2018 14:04:03	Ant Home: /usr/share/ant/
So according to this article: https://confluence.atlassian.com/bamkb/cannot-execute-ant-builds-ant-does-not-launch-213524968.html , I was expecting the remote agent to see ANT_HOME when launching and set it accordingly, but looking at the log for the Ant build task, I see it setting its own ANT_HOME:
using extra environment variables:
... etc
ANT_HOME=/usr
... etc
Ant works 100% fine as configured in any users bash shell, so this is definitely something with how bamboo is setting up the execution environment for the ant build task.
Any thoughts?
Gonchik Tsymzhitov
February 10, 2019
Hi!
Have you fixed it ?
Gonchik Tsymzhitov
