I upgraded from 4.0 to 4.2 and now I have script tasks that will not run.
I give it the file name, a Windows batch script (.bat) and the directory it's located in.
Bamboo spits back errors:
"Unable to find exectuable at genproj.bat"
"Access is denied"
"Access is denied"
"Access is denied"
The script runs through additional subfolders setting up some structures so it looks like it actually is running the script but why is the task failing?
My bamboo agent on the build agent has not changed from when it worked with 4.0
Linux Bamboo build server, WindowsXP build agent
We have verified this as a bug in https://jira.atlassian.com/browse/BAM-12124. The workaround at the moment is to specify the full path where the batch file is placed
Eddie, you don't need to update agent jars.
Did you update the remote agent to be the 4.2 jar, is ist running under the same user? Can you manually execute that script as the user that runs the bamboo remtoe agent?
Can you attach a sceenshot of your task configuration? Also, does the agent run as a service?
My image isn't uploading for some reason
But the configuration is like this
Task Description: Generate Project Files
Script Location: File
Script File: genproj.bat
Agrument: blank
Environment Variables: blank
Working Sub Directory: location_of_script (only 1 level down from the top level directory)
The agent is running as a service
What if you change it to:
Script File: location_of_script/genproj.bat
Working Sub Directory: location_of_script (or whatever you need)
It is running as a service.
I am also having the same problem since upgrading Bamboo to 4.2.
I have a similar set-up to the one above where I use the Script Task to run a batch file. I am now getting an error saying that the file is no longer recognised as a batch file, thus causing the build to break.
Here is the error in the logs:
simple Starting task 'Moving files to profile.franchisee.com folder' of type 'com.atlassian.bamboo.plugins.scripttask:task.builder.script'
error Unable to find executable at Move_files.bat
command Beginning to execute external process for build 'Franchisee Profile - Move files'\n ...running command line: \nMove_files.bat\n ... in: E:\bamboo-home\xml-data\build-dir\FP-TRANSFER\n
error 'Move_files.bat' is not recognized as an internal or external command, operable program or batch file.
I tried your suggestion above to fill in the full path to the batch file, but as this folder name will change each time a build will run, this is not an option.
Is this a known issue in 4.2 or should I open a ticket for it?
Sinead
