×Using 'Artifactory Nuget' build task with Capture Build Info selected it is not setting the properties on the artifacts for build.name and build.info. It's only setting nuget.* properties. This prevents the repo_path from showing when displaying the artifacts from the build screen. Not sure if this is a bug or feature request?
