This is working with the 'Legacy Patterns' but gets a 404 using the file spec option. The file spec option is working on the deploy task side. Anyone else seen this behavior or have a solution?
Bamboo Artifactory Plugin version: 3.2.8
Bamboo version 8.0.4 build 80012
Artifactory version 7.35.2
Successful deployment log
31-Mar-2022 10:14:02 Starting task 'test artifactory upload' of type 'org.jfrog.bamboo.bamboo-artifactory-plugin:artifactoryDeploymentTask'
31-Mar-2022 10:14:02 Usage info sent successfully.
31-Mar-2022 10:14:02 Using task configuration spec
31-Mar-2022 10:14:02 Spec: { "files": [ { "pattern": "/media/data/bamboo-work/tower/", "target": "devops-generic-local/tower2/" } ]}
31-Mar-2022 10:14:02 [consumer_0] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower2/README.md
31-Mar-2022 10:14:02 [consumer_1] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower2/tower_launch.py
31-Mar-2022 10:14:02 [consumer_2] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower2/tower_launch_example.json
31-Mar-2022 10:14:03 [consumer_1] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower2/tower_launch_requirements.in
31-Mar-2022 10:14:03 [consumer_2] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower2/tower_launch_requirements.txt
31-Mar-2022 10:14:03 Finished task 'test artifactory upload' with result: Success
31-Mar-2022 10:14:03 Finalising the build...
31-Mar-2022 10:14:03 Stopping timer.
31-Mar-2022 10:14:03 Build 29753346-30081025-30244866 completed.
31-Mar-2022 10:14:04 Finished processing deployment result Deployment of 'release-1' on 'test'
Failed build log
31-Mar-2022 16:32:33 Starting task 'test artifactory upload' of type 'org.jfrog.bamboo.bamboo-artifactory-plugin:artifactoryGenericTask'
31-Mar-2022 16:32:33 Usage info sent successfully.
31-Mar-2022 16:32:33 Bamboo Artifactory Plugin version: 3.2.8
31-Mar-2022 16:32:33 Using task configuration spec
31-Mar-2022 16:32:33 Spec: { "files": [ { "pattern": "E:/bamboo-work/tower/*.md", "target": "devops-generic-local/tower4/" } ]}
31-Mar-2022 16:32:33 [consumer_1] Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower4/README.md
31-Mar-2022 16:32:33 Response received: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
31-Dec-1969 19:00:00 <html xmlns="http://www.w3.org/1999/xhtml">
31-Dec-1969 19:00:00 <head>
31-Dec-1969 19:00:00 <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"/>
31-Dec-1969 19:00:00 <title>404 - File or directory not found.</title>
31-Dec-1969 19:00:00 <style type="text/css">
Success build log using legacy input
31-Mar-2022 16:38:07 Starting task 'test artifactory upload' of type 'org.jfrog.bamboo.bamboo-artifactory-plugin:artifactoryGenericTask'
31-Mar-2022 16:38:07 Usage info sent successfully.
31-Mar-2022 16:38:07 Bamboo Artifactory Plugin version: 3.2.8
31-Mar-2022 16:38:07 For pattern: E:/bamboo-work/tower/* 5 artifacts were found
31-Mar-2022 16:38:07 Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower5/tower_launch_example.json
31-Mar-2022 16:38:07 Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower5/README.md
31-Mar-2022 16:38:08 Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower5/tower_launch.py
31-Mar-2022 16:38:08 Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower5/tower_launch_requirements.in
31-Mar-2022 16:38:08 Deploying artifact: https://artifactory.dev.medpro.com/artifactory/devops-generic-local/tower5/tower_launch_requirements.txt
31-Mar-2022 16:38:08 Finished task 'test artifactory upload' with result: Success
