I get this error intermittently on Branch Integration pushes:
Push command error: Warning: Permanently added '[127.0.0.1]:59319' (RSA) to the list of known hosts.
fatal: The remote end hung up unexpectedly
It may happen for five branches in a row, then the sixth branch will push the changes with no issue (or human intervention).
Is there a way to make the push process more consistent?
Might be related to the following.
* http://stackoverflow.com/questions/6808653/fatal-the-remote-end-hung-up-unexpectedly-while-pushing-to-git-repository
* http://stackoverflow.com/questions/15240815/git-fatal-the-remote-end-hung-up-unexpectedly
Check if your keys and token are properly setup and try to change to ssh instead of http.
I have it configured to use SSH and does work some of the time, but it fails fairly regularly - perhaps 50% of the time or more.
