Bamboo 5.12 compatibility with third-party add-ons and other Atlassian products
Sergei Jerdetski May 25, 2016
Hi there,
  1. I wonder if upgrading Bamboo from our current version 5.7.2 to the latest one (5.12) would require any respective updates for other Atlassian products our company is currently using, namely JIRA (current version 6.3.13), FishEye (3.4.3) and Confluence (5.8.4): if so, would you please be specific as to what minimum upgrade(s) will be necessary for each of the aforementioned products in order for them to be compatible with the latest Bamboo version 5.12?
  2. We currently have several third party add-ons (user-installed) - please see the entire list below - we want to continue to use: will upgrading Bamboo to its latest 5.12 version still make it possible for our company to keep them? Are all (or most) of the following add-ons currently supported in Bamboo 5.12 (or at least different versions of these):
        JMeter Aggregator (the most important for us to keep) (version 5.7.1)
        PowerShell Task  (also very important) (version 1.1.9)
        Agent Utilities - Basic (version 1.0)
        Atlassian Universal Plugin Manager Plugin (version 2.20.4)
        Bamboo Build Times Plugin (version 1.0)
        bamboo-group-agent  (version 1.7)
        Bamboo Node.js Support (version 1.7)
        Bamboo System Banner (version 1.1)
Thank you in advance for your time and assistance.
Sergei Jerdetski
DevOps Engineer
Health Language
Wolters Kluwer Health
4600 S Syracuse St, Suite 1200
Denver, CO 80237
Alexey Chystoprudov
May 26, 2016
Hello @Sergei Jerdetski,
  1. You don't need to upgrade other Atlassian tools
    1. JMeter Aggregator was marked compatible with 5.12.1
    2. PowerShell Task is not managed by Atlassian
    3. Agent Utilities - Basic is not managed by Atlassian
    4. Atlassian UPM plugin 2.20.4 not tested, but Bamboo has bundled UPM plugin
    5. Bamboo Build Times Plugin is compatible
    6. bamboo-group-agent is not managed by Atlassian
    7. Bamboo Node.js Support is bundled with Bamboo 5.12, so you don't need to install it from Marketplace
    8. Bamboo System Banner is not managed by Atlassian
Krystian Brazulewicz
February 23, 2017
Powershell support is built into Bamboo so you might want to give it a try.
Like • Steffen Opel _Utoolity_ likes this
