Following configuration here https://confluence.atlassian.com/display/CROWD/Integrating+Crowd+with+Atlassian+Bamboo get this exception when starting bamboo.
java.lang.ClassNotFoundException: com.atlassian.crowd.integration.seraph.v22.BambooAuthenticator
This has been configured to authenticate via forms with Crowd successfully, but SSO is failing.
Can you try using com.atlassian.crowd.integration.seraph.v25.BambooAuthenticator instead?
I have a fundamental problem with my Crowd installation which I'm unable to determine the root cause. I'm going to delete the install and start from scratch.
