Bamboo 7 and Oracle 12.1
Jörg Lang August 13, 2020
We have Upgraded Bamboo to latest version and we now have the problem tht bamboo isn't starting up.
error in log:
FATAL [localhost-startStop-1] [DefaultBootstrapManager] Validation tests failed: [Task 51111 failed with exception: Bamboo doesn't support Oracle version Oracle Database 12c Enterprise Edition Release 12.1.0.2.0 - 64bit Production
With the Partitioning, Real Application Clusters, Automatic Storage Management, OLAP,
Advanced Analytics and Real Application Testing options. Please check https://confluence.atlassian.com/display/BAMBOO/Supported+Platforms for more information.]
FATAL [localhost-startStop-1] [DefaultBootstrapManager] Validation tests failed: Your Bamboo instance could not start because health check failed. Contact Atlassian Support at https://support.atlassian.com
We are running Bamboo as Windows Service and have set
-Dbamboo.enable.unsupported.db="true"
in the java properties but it seams not to work.
Any ideas on that?
Jeyanthan I
September 8, 2020
Hi @Jörg Lang and @parthiban_selvaraj,
It is possible that you might have added this parameter under bin/setenv.sh. If you are starting Bamboo as a service, you will need to configure either via the command line or in the Windows registry as explained in this page and restart the server.
Hope that helps.
Jey
parthiban_selvaraj September 8, 2020
Did you solve this issue?
