Bamboo Artifacts directory
Young__Hahn August 31, 2016
Question about the Bamboo Artifacts directory.
It looks like bamboo doesnt automatically deletes the artifact plan file(?) automatically even after we delete/remove the plan..
i still see something like
drwxr-xr-x. 3 root root 19 Aug 12 17:25 plan-786443
when i deleted this plan the same day..
and this files are few GBs..
is there a way to delete this plan automatically? so that it doesn't fill up the storage size?
Not sure if it is good to keep or delete..
Krystian Brazulewicz
August 31, 2016
This directory should be removed when the plan was removed. Please note that plan removal is done in the background so it might take a while before all data related to the Plan is deleted (it depends mainly on number of builds of a given plan).
If such problem will occur again please contact our Support
